To cut a long story short. Was driving today and the car seemed to accelerate without me making it. I pushed the clutch and pulled it into neutral and the engine reved quickly up to 9000 by itself and stayed there until i was able to cut the power to the fuel pump (luckily i have a kill switch). Im guessing that the accelerator cable got stuck but it seems fine and im worried that it could be caused by something else - maybe turbo/boosting related? I wasn't driving the car hard at all when it happened.
what would cause the engine to spike to 9000 revs and stay there? besides the accelerator cable/pedal getting caught or stuck.
my car seems fine now but im scared to drive it without knowing what may have caused it since the cable doesnt seem like it had anything to get caught on.
any help/opinions would be appreciated.
  • Replies 41
i've had a loose throttle cable slip off when the throttle was half open and stick like that, then be back in place by the time i stopped the car and lifted the hood. If the throttle body is closed, the engine cant rev. It has to be the throttle sticking somewhere
Or a hose.
I had some hose get loose and get jammed in the throttle body.
I forgot to use a cable tie after i was changing the plugs or something and it moved in the way.
No harm done
Same. The hose.
Was mid burn out, started getting out of shape, backed off.... hose says no.
For reference, its not lucky you have a kill switch, everyone should be aware you can simply turn the key off, throttles getting stuck is not that uncommon, don't panic, just turn the key off.
Careful with the key, too far and you will be dealing with the steering lock.
Or just go up a gear, 4th to 5th and jump on the brakes till you cna sort out turning the ignition off.
Thats what i had to do as i wasnt sure what was going on.
It isnt good for the car, but the rev limiter is there and does the job, but better than getting too outta shape.
I'd rather f**k a clutch than have somethin bad happen
My story is good.
The same thing happened to me. Nailed it at the lights and then the throttle jammed open somehow, car rocketed down the street, evetually switched it off and rolled to a stop. Upon inspection, the f**king trumpet from my GFB Bov had unscrewed, and jumped across the engine bay coming to rest under the throttle lever leaving it wedged fully open :kiss:
I made sure I screwed it on extra tight afterwards. Seriously though, what are the chances of that?
Don't you have to take the key out of the ignition before the steering locks?
dont think so, if the cars off and you move the steering wheel to far to either side it'll lock it with the keys still in the ignition.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
