  • Replies 41
what? the r33's? if you say so..........
on my r32 the doesnt lock till the key comes out.
steve
My R32 locks with the key in it, but it does have to be in the off position.
When you first shove the key in it how do you unlock the steering wheel?
I am required to turn it to the acc. positon with a little wiggle of the steering wheel. I would think if locked once they key is slid out then it must also unlock by simply sliding the key in.
Thanks guys, nah, i just thought someone went happy modding on me.
I suggested that cutting the fuel pump is not a good idea. especially at 9k rpm.
Motors have been killed by a fuel pump failing at wot. Cutting the ignition would be a better idea.
Yeah that was exactly the point I was raising. I don't think cutting the fuel is the best way to stop an engine running at 9000rpm. Don't be a custo, just turn it a little way, its not hard to feel the first click in the off position with no steering lock. Interesting topic though, seems a few people have had similar issues.
One time a padock basher brumby I had, got throttle stuck open, but then went one better, kept going once key was off as it was running unleaded fuel (when it shouldnt have been) and the little thrash had it pre-igniting. so ignition off, then it kept going, so i slammed it into 4th and pulled the hand brake on, it tried for a little then died....
dude you arnt going crazy, theres a second post thats exactly the same in a differant section!!
i went through it and though the mods cut sik at it, but i guess they havnt spotted the second one.
steve
To update:
The problem remains and this time i paid more attention and it doesnt feel like the throttle gets "stuck", but it feels like it actually accelerates and opens up. I mean it feels like the throttle just opens up itself. Both times it happened I was going pretty slow and accelerating in second gear at very pretty low revs.
I spent yesterday making sure there were no cables, wires etc near the throttle cable and accel pedal.
The whole cable and throttle spring/mechanism etc feels excellent - no sticking or anything.
Also had a look inside the throttle body at the butterfly valve thing and it seems to move fine and not be loose or sticky. Lubed up the cable so it couldnt stick and did everything I could to basically make sure the cable or throttle mechanism had nothing around it to interfer.
Then, after driving the car around for over 2 hours, it happened again. Was in second gear and was starting off slowly... revving maybe 2000rpm in second gear and accelerating slowly - then it felt like it was accelerating harder and i took my foot off the pedal and it kept accelerating, took it out of gear - revs shot up - i killed the ignition, stopped, looked under the hood at the cable and it was free and restarted and the car was fine.
I have the older rb20det NICS type and thing think it has something to do with the idle mechanism... i have no idea how it works but i figure something has to give the car throttle when your not touching the pedal so that it idles... and maybe this opens up or gets loose or something.
In this post -> post http://www.skylinesaustralia.com/forums/in...howtopic=124145
someone talks about a faulty aac valve (?) and a valve UNDERNEATH the inlet plenum/manifold that adds air according to coolant temp based on maps in your ecu.. (?)
I'm really just taking a stab in the dark - please help!! I'm really stuck with what to do.
or just takle it somewhere to get it checked :)
perhaps the return spring(s) are broken. both on the pedal and on the throttle body.
also the tps has a spring too. it would be hard to put it on backwards though
The AAC at maximum open will only hold your revs at around 1600....not 9000. If the throttle is shut...the car cannot rev. Your problem must be throttle related. it is physically impossible to increase the revs that much but not allow any more air to enter, the engine would choke and die.
Does the accelerator pedal return to it's normal position when this happens?
Do you have any kind of cruise control fitted to your vehicle?
no cruise control
and i think the pedal felt like it was stationary... To be honest it all happened so fast that i could be wrong - the pedal might have moved... i AM sure that it wasnt stuck. And i AM sure that when I stopped the car (like 1 second after it happened) the pedal and the throttle mechanism were both in the usual position and not caught/stuck or in an unusual position.
what about the cold idle valve?
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
