Hey just wondering if any one could tell me if optimax is 96 or 98 octane. I normally fill up at BP on 98 octane (premium) but filled up on optimax today.. Since filling up on the stuff my car has lost all power and feels like it did before installation of my new pump (slow as crap, no power at boost, farting etc).. This has all co-incided with my alternator/battery getting consistently worse, and i was just wondering if the optimax was 96 octane, because that would probably make more sense, than my battery/alternator getting worse so fast
thx
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/124055-optimax-96-or-98-octane/
hi
Ive always sworn by BPultimate & optimax but just last week i got about 50kms more out of a tank using Mobil petrol(synergy). I only used it by chance but it worked out better. the performance improved aswell & i was using the power a little more, compared to with the other fuels.
My friend had the same situation with his 05wrx, he agreed. i have a r34 and ill be using Mobil more regularly now.
cheers
steve
hi
cheers
steve
I hear the synergy is better then ultimate or optimax. I wish we had it in QLD. I always used bp, as their fuel is refined to 98 ron while optimax ( from what I have been told) has sh*t added in to bring it up to 98 ron
I was under the impression that Optimax was actually 99RON. I remember reading something about it a while back, it is the highest octane fuel available (until they released Extreme - 100RON).
Also, the V8 Supercars use Optimax, so it can't be that bad, I have used all 4 types of Hi-Octane Premium, and I am buggered if I can tell the difference.
Yeh sorry meant ultimate not premium. Filled up with ultimate today and its better. Doesn't stutter anymore and pulls harder on boost (althought not as hard as it did before putting optm.. weird..) Probably some rooted fuel related sensoor somewhere doesnt like the optimax and makes my car frig up or something. Ill try the mobil tomorrow and post back if i notice any difference
Shell Optimax 98
Shell Optimax Extreme 100
Mobil Synergy 8000 98
BP Ultimate 98
United Boost 98 Umm 98 maybe
Some cars dont like to be run on Optimax due to the additives that are in the fuel, detergents etc can foul the plugs (heard of it being more common on motorbikes) My old car used to get the occassional miss and get 50 kms less to a tank when i used the Optimax
And with the new car, i use BP Ultimate and Mobil 8000, never had any dramas with either of these.
This subject has been discussed so many times in so many threads. I am not going to tell the whole story again, if you want more than this post do a post search, "Sydneykid" and "refinery".
Oil companies have a policy called "refinery sharing/exchange" because it is simply not economical for each oil company to have a fully equiped refinery in each state. Refineries need volume to make money, it's that simple. Do a Google search on "oil refinery sharing", you will find ALL oil companies in Australia refinery share.
For example, there is NO BP REFINERY IN MELBOURNE, so do you think they ship it in, millions of litres per week in tankers from WA or Qld? Like hell, they refinery share and buy (swap) the fuel from a local refinery. If you want to know what refineries are in Melbourne (don't forget Geelong) look it up in your yellow pages. When you buy fuel at a BP servo, chances are you will be pumping fuel from one of those refineries not a BP refinery.
A quote from the BP Australia web site tell it all....
"A particular feature of the Australian oil industry is the practice of refinery exchange, in which refining companies exchange products in various locations to minimise distribution costs. For example, BP supplies other companies in Perth and Brisbane and in return is supplied with product in Melbourne, Sydney and Tasmania."
:D cheers :P
Edited by Sydneykid
thx
no, it doesn't make more sense. your rough running problems are much more likely (ie 99.99999999%) to be caused by your charging problem resulting in poor/weak spark. This would be especially noticeable under load/boost or at night (ie when your lights are on).
Edited by hrd-hr30
most of the "perceived" differences in 98 octane fuels are usually just in your head. I have a friend who works for shell, who says all the 98 octane fuel is exactly the same, (actually not technically true, i think the united boost uses ethanol in their fuel)
though, i do have a couple of friends who call optimax "opti-ping"....
i generally use either optimax or bp ultimate, and i don't notice any difference at all
I fill up with BP when I don't have a 4c discount docket, but when I do, I fill up at Shell. So my 32 is pretty much 50/50 on Ultimate and Optimax and tbh I notice no difference swapping fuels.
And from what Sydneykid said, it's probably because it's all the same anyway!
ive heard all the fuel myths and dont believe any of them myself.
ive heard more than 50ks difference on a given brand xyz fuel rating (sounds like driver habits if anything).
ive heard more or less engine and performance between 98 rated brands and so on. ive always used optimax and never had problems. ive tried the other brands as a bit of humour to try out some rumour and it all feels the same.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
