Group buy for Braided master to slave cylinder clutch lines.
These replace all the piping and the junction block and the factory rubber hose.
Similar to this:
Replaces all the piping as in this pic:
Product:
- Replacement stainless clutch line.
- ADR approved.
- Manufactured by MALTECH.
- Available for R32 GTST, R33 GTST, R34 GTT, R32 GTR, R33 GTR, R34 GTR, WGNC34.
- Insert Colours - red, blue, smoked, black.
- Plastic coating is also avaialble (for same price) - red, blue, black, clear.
Prices:
5 buyers:
R32 GTST - R33 GTST - $85.00each (rrp- $90.00each)
R34 GTT - R32 GTR - R33 GTR - R34 GTR - $90.00each (rrp- $95.00each)
STAGEA RS4 Series 1 (manual conversion) - $85.00each (rrp- $90.00each)
STAGEA RS4 Series 2 - $90.00 each (rrp- $95.00each)
10 buyers:
R32 GTST - R33 GTST - $80.00each (rrp- $90.00each)
R34 GTT - R32 GTR - R33 GTR - R34 GTR - $85.00 each (rrp- $95.00each)
STAGEA RS4 Series 1 (manual conversion) - $80.00each (rrp- $90.00each)
STAGEA RS4 Series 2 - $85.00 each (rrp- $95.00each)
Also available- 180SX - S13 - S14 - S15 (rrp- $90.00each)
Postage (1-2 sets) - $7.50 express within Australia.
Finish date - 28/09/06
Payment due - 01/10/06
1/ IMPUL R32-R - R32 GTST - blue inserts - clear coating
2/ willsy - R32 GTSt - black inserts - clear coating
3/ darrinspencer - stagea - black inserts - smoked coating
4/ boss33 - R33 GTST - blue inserts - blue coating
5/ private buyer
6/ clincha - R32 GTST - blue inserts - clear coating
7/
8/
9/
10/
  • Replies 45
I need a odd one
R34 GTT master cyclinder
R33 GTR slave cylinder
Length to suit a Stagea, should be the same as a R34GTT
Smoked hose, black ends
I need a odd one
No probs. Its available and is the same price as the R34 GTT line.
Shall I add you to the list?
ALSO AVAILABLE:
STAGEA RS4 Series 1 - $75.00each (rrp- $90.00each)
STAGEA RS4 Series 2 - CAN ANY ONE CONFIRM IF THE SERIES 2 MASTER TO SLAVE IS THE SAME AS THE SERIES 1??
ALSO AVAILABLE:
Series 1 Stagea only ever came out as a auto from the factory except Autech 260RS Rb26dett
Series 2 Stagea came as a factory manual or tiptronic auto
Yes I want one
My car is a series 2 auto that I am converting to manual
Hope that clears things up
My line arrived today in the post (I ordered it directly from Maltech, wasnt aware of this groupbuy).
Great looking line and excellent service from Maltech.
Greddy,
can you get the ones from maltech that just replace the rubber section of the pipe? I dont want a braided line like in your first pic, i want one that just replaces the rubber section in the second pic.
Thanks mate!
Greddy,
Thanks mate!
PM sent :D
is this group buy still going? im interested in getting a braided clutch line for my gtt
This group buy is still going.
Finish date - 10/07/06
Payment due - 15/07/06
Shall I add you in?
:whistling:
anyone else?
I need more buyers to offer them for the good price.
:blink:
Put me in for a stainless one for gtr33
Smoke clear coated
Thanks
Is this still going ahead?
  • 4 weeks later...
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
