This is the info i got of the previous owner who had it on a r34 gt-t and i had it fitted to a r32gts-t.
HKS Oil Cooler uses special size core designed for each car by considering about engine performance, engine sizes and body shapes. Thermostat controls Oil Temperature As HKS oil cooler uses special core that is excellent for cooling purpose, this oil cooler has thermostat to prevent overcool . This thermostat is very good at responding to temperature change and also acts as relief valve. When engine oil gets hotter than thermostat temperature setting (70C 3C), it will run into oil cooler core and be cooled down. When engine oil is cooler than above temperature, it will bypass the core and keep oil temperature in best condition. By acting thermostat as relief valve, HKS considered safety in an emergency. In the case of extraordinary high oil pressure caused by squashed core or blocked line, etc..., thermostat acts as a relief valve and engine oil bypasses core. By this way engine will be protected and line breakage will be prevented. S TYPE (sandwich type) This type uses special attachment that has thermostat in itself. This attachment goes on the oil filter support and oil filter goes on to this oil cooler attachment. S TYPE oil cooler kit is superior to R TYPE for their value for money, because less parts are needed for fitting. this unit was fitted to R34 GT-T previous owner, then a r32 gts-t with an rb20det, genuine japanese quality kit ..over $900 new to buy
$400
Elliot 0417 125 125. 30mins N.e of the city in melb.
Edited by KLR32
Sorry again guys, but it has been available since the start of march and on ebay countless times i couldn't believe myself its taken this long to sell!
i thought this sold on ebay not long ago???
http://cgi.ebay.com.au/Hks-oil-cooler-skyl...1QQcmdZViewItem
The guy who one it bidded for a mate and didn't end up wanting it in the end so i had to pay for the fees which has happened a few times to me already this month on ebay.
Guest
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
