ok, my r33 has an atmo bov on it and ive noticed that it sometimes idle kinda wierd and other symtoms of a non plumback bov. well looking at getting a plum back bov when i get my tax back and i kinda go nfi how to go about the plum back part...
like what size hose etc and where it reconnects before the afm.
ive attached a pic (i work better with pics...) and yes the airfilter is due for a clean i think...
any help will be appreciated :P i think the afm is the thing after the pod right? (my last car was a commodore and less technical :) )
https://www.sau.com.au/forums/topic/124114-going-from-an-atmo-bov-to-plumback/
its all there ready to be clamped on. there should be something blocking off the hose so take it off and attach it to your new bov.
if you've got idling issues i think you should do a search on "AAC Valve" that'll get you started.
If you can mate I recomend going back to the stock BOV, can handle plenty of boost and give you no dramas like the Atmo. It looks like your intake pipe isnt standard though, so u might have some dramas, have you got a photo of where your BOV is mounted?
Cheers
Take a pic of the crossover pipe so I can see if the factory Bov is still on there, mine had a thin plate between the crossover pipe and the Factory BOV that blocked it off and all I had to do was remove that plate and block the atmo hole off .
in that case its just a matter of swapping them over. it consists of 2x12mm bolts holding the BOV in, a vacuum hose and a hose with 2 clamps to fit onto the stocky.
i'll take a pic of it close up for you tomorrow.
yeah the thing with the grey cap. if you open it the little dipstick (about an inch long) will have a line on each side. one has hot, the other cold. this is due to the fact that the fluid expands when hot (or is it cold.... i can't remember). but anyway check it according to whether it is hot or cold on the corresponding marks.
With K&N filters they rely on some dirt to help aid filtering, but without effecting flow levels.
So making it really clean again will mean more particles going into the engine.
I don't know how dirty it is, from those pics, just be-aware that some dirt is required to get them to filter well. (Its all stated on the back of the boxes)
I hate when people do a filter test for filtration levels and they use a brand new filter and and say K&N doesn't filter as well as other filters.
Yet they don't realise or state K&N specify some dirt helps it filter properly, hence not needing to be cleaned for up to 100k km in some cases.
oh, never read that... then again ive never bought a k&n filter... it is pretty dirty tho. im tossing up buying the cleaning kit thingy or even an apexi pod... ill prob go the cheaper option...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
