Hi im wondering if u guys who r running a Power FC could advise on which type of boost controller would best suit it? Can I use it along with a manual type valve like a Turbotech or would it have to be an electronic type like the AVCR? There seems to be a huge difference in price between these types of valves so I would just like to know which would work best with it and why. Obviously the EBC type would allow adjustment from the cabin but what other advantages does it have and is it worth the money?
I would also like to find out if the Commander unit can double as a boost gauge amongst the other info it reads? On the Apexi Power FC specs http://www.apexi-usa.com/product_electroni...d=197&pageNum=1 it mentions that the Commander can display up to 10 parameters of data in real time. Boost is one of them so I assume that this means it basically reads current boost pressure. Reason im askin is I need to get a boost gauge as the stock one in the car is inaccurate but if the Commander doubles as one I could save myself the trouble.
Im still fairly new to the aftermarket ECU scene and am trying to find out as much as I can about it before I get one so any help would be appreciated. Cheers.
https://www.sau.com.au/forums/topic/124130-which-boost-controller-for-power-fc/
For the Apexi Commander to read boost, you would need the additional boost control kit that comes with the Power FC. However most people run a seperate boost controller, be it a electric, or a mechanical (such as Turbotech).
There's no shortage of information on mechanical Vs electric boost controllers. I am happy with my turbotech / PFC combo on my 180sx.
take from the power fc faq:
Boost display without the Boost Control Kit?
By default as the PowerFC will not show boost pressure as it has no method of reading it in via the stock ECU loom. If you purchase a suitable map sensor and connect it to the PowerFC boost control kit port then the hand controller will display boost pressure. The boost control kit uses a Denso map sensor which is part #DPS 310 2000a - Denso 949940 6270 5V and the wiring loom cable/plug can be brought from Apexi which is around $40 AU. The cable is listed as the 3pin boost control harness. Nengun has this listed under Electronics -> Apexi -> D Jetro Option Parts
We use the Power FC Boost Control Kit, works a charm, no ricey blue screen or other crap to clutter up the cabin. Plumb it up, plug it in and punch up the desired boost level on the Commander and away you go.
:kiss: cheers :rofl:
The EBC kit that is an optional xtra for the PFC is a rather expensive kit at $440 although im sure some will argue that u get wot u pay for. I may opt for a manual type control valve at this stage and perhaps move onto a EBC when i can afford one.
As for the Commander reading boost, im gathering from wot Paul said, that u will need to get a MAP sensor & wire one in for this function to work. 2 bar MAP sensors ~$139
So ill probably be better off to just get a separete boost gauge and forget about trying to use the Commander to double as my gauge. Where does the sensor for a boost gauge go?
The same place as the boost kit one would go, tap into the manifold vacuum lines.
Closer to the actuator input signal would be ideal. Also it is very useful on the hand controller as you have logging ability and history view and also can display it in real time with other values next to it.
IMHO it would be much more useful on the hand controller than on a seperate guage in the pillar or somewhere else
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
