any1 know where the odometer is connected to? diff or gearbox?
after recently servicing my car, i went and fuel up then reset my Km's clock, after that i relise it stop clicking the km's. thought i might have jammed it but the main readings should still work. cant figure out why it all suddenly stopped! even the main one stop if the reset switch is jammed.
everything else on the dash works perfectly, fuel, boost, oil pressure speed, temp etc etc.
https://www.sau.com.au/forums/topic/124146-odometer/
    • Just the down shift from 5th to 4th is crunching
    • I was told to put in vmx80 for about 500kms. Then change to Motul 75w90 it goes into all gears smoothly, I do hear a slight hissing noise when release clutch
    • My fourth gear is not perfect but I hard shifted it into fourth from fifth and its shifting better now. Not bothering me atleast.  I think the cheapest option is to replace the whole transmission for a R33 heritage one for like 1500 USD not including the shipping. Thats what I was going to do but its not bothering me anymore. What is bothering me is my idle is weak now after I change my intake to a smaller one so I need a tune again - loves to stall in reverse and when the aircon is on lol ... Love these older cars. WOT is strong though.
    • Either you specced the wrong fluid or your clutch is not releasing properly for whatever reason.
    • Did you manage to fix the problem? I’m having the same issue but everything is new in my gearbox
