Here is an interesting disscusion I found online about the toyota CT26 turbo.
http://www.mr2.com/TEXT/CT26TurboLimits.html
Just wondering is there are ant people with indepth turbo knowledge that might be able to read it and say if what is being said is true.
If it is then a CT26 Supra turbo might be a geed upgrade for a standard SR or CA or as the CT26 has a ceramic wheel like the skyline the same theory might be able to be applied to that turbo also.
I have been trying to find info on putting the skyline turbo on smaller engines and the boost that can be run before the turbine wheel falls off.?
Just let me know what you think.
https://www.sau.com.au/forums/topic/12415-turbo-theory/
Hi Arron, most of what is written on the CT26 is OK. But they are missing two points;
Heat kills ceramic turbines just as quickly as boost.
So you can have a turbine that lasts for years at 12 psi gently driven on the street or one that last 5 laps at 10 psi on the track. There are two extremes and I (nor any else for that matter) know which end of the scale your requimements are at.
The second issue is they have totally ignored the effect of more boost on the engine. I can have a turbo that flows 300 bhp at 1 bar or another that flows 300 bhp at 1.3 bar. The 1.3 bar one is obviously harder on the engine (as well as itself) than the 1 bar one.
My preferred upgrade for a SR20 or CA18 is the R33 RB25DET turbo which in standard form at 10 psi will give 25 rwkw more than the standard turbo. You obviously need to have the support around the turbo, eg; fuel flow, air inlet, intercooler and exhaust, to sustain this power level.
Hope that helps
https://www.sau.com.au/forums/topic/12415-turbo-theory/#findComment-225542
I have most the support for about 200 to 240 rwkw.
APEXi FC
550cc injectors
80mm afm
going to get a bigger fuel pump
have just got another front mount intercooler (third one..... its a long story)
just looking for a bigger turbo, I really only need / want around 200rwkw.
https://www.sau.com.au/forums/topic/12415-turbo-theory/#findComment-225778
Hi Arron Sutton, I would go hi flowed RB25DET turbo, make a nice 200 rwkw which is the limit for the internals (rods and pistons) on a CA18. Cost about $2200
Or a new Garrett GT28 with these specs for $2300:-
0.64a/r Turbine Housing (5 bolt outlet)
0.60a/r Compressor Housing (TB03)
Watercooled Centre
60 Trim Compressor Wheel
62 Trim Turbine Wheel
Integral Wastegate
Hope that helps
https://www.sau.com.au/forums/topic/12415-turbo-theory/#findComment-225820
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
