Here is an interesting disscusion I found online about the toyota CT26 turbo.
http://www.mr2.com/TEXT/CT26TurboLimits.html
Just wondering is there are ant people with indepth turbo knowledge that might be able to read it and say if what is being said is true.
If it is then a CT26 Supra turbo might be a geed upgrade for a standard SR or CA or as the CT26 has a ceramic wheel like the skyline the same theory might be able to be applied to that turbo also.
I have been trying to find info on putting the skyline turbo on smaller engines and the boost that can be run before the turbine wheel falls off.?
Just let me know what you think.
https://www.sau.com.au/forums/topic/12415-turbo-theory/
Hi Arron, most of what is written on the CT26 is OK. But they are missing two points;
Heat kills ceramic turbines just as quickly as boost.
So you can have a turbine that lasts for years at 12 psi gently driven on the street or one that last 5 laps at 10 psi on the track. There are two extremes and I (nor any else for that matter) know which end of the scale your requimements are at.
The second issue is they have totally ignored the effect of more boost on the engine. I can have a turbo that flows 300 bhp at 1 bar or another that flows 300 bhp at 1.3 bar. The 1.3 bar one is obviously harder on the engine (as well as itself) than the 1 bar one.
My preferred upgrade for a SR20 or CA18 is the R33 RB25DET turbo which in standard form at 10 psi will give 25 rwkw more than the standard turbo. You obviously need to have the support around the turbo, eg; fuel flow, air inlet, intercooler and exhaust, to sustain this power level.
Hope that helps
https://www.sau.com.au/forums/topic/12415-turbo-theory/#findComment-225542
I have most the support for about 200 to 240 rwkw.
APEXi FC
550cc injectors
80mm afm
going to get a bigger fuel pump
have just got another front mount intercooler (third one..... its a long story)
just looking for a bigger turbo, I really only need / want around 200rwkw.
https://www.sau.com.au/forums/topic/12415-turbo-theory/#findComment-225778
Hi Arron Sutton, I would go hi flowed RB25DET turbo, make a nice 200 rwkw which is the limit for the internals (rods and pistons) on a CA18. Cost about $2200
Or a new Garrett GT28 with these specs for $2300:-
0.64a/r Turbine Housing (5 bolt outlet)
0.60a/r Compressor Housing (TB03)
Watercooled Centre
60 Trim Compressor Wheel
62 Trim Turbine Wheel
Integral Wastegate
Hope that helps
https://www.sau.com.au/forums/topic/12415-turbo-theory/#findComment-225820
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
    • I have a wheel cleaner pokie thing which is a glorified microfibre rag on a stick, and there is not sufficient clearance between the caliper and the barrel to clean that section. I just roll the car forward 500mm and have another shot at each wheel.
    • The "rag on a stick" is a easy way to fit in between the wheel spokes into all of the barrel Albeit I do have 10 spokes on the MX5 which limits the access to actually jam my hand in to clean the barrel, but it was also makes much easier to clean the 5 spokes on the Dunnydoore with it as well, as you don't have to worry theΒ  caliper getting in the way if you have at least about 15mm space between the caliper and barrel This of course depends if you actually have the clearance between the barrel and caliper, and the amount of OCD you have to get the barrels as clean and shiny as the face of the wheel The thing is bendy as well so you can actually shape it to conform to the inner lip of the barrel Β
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.Β Β  Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
Γ—
Γ—
