You'll find that a Ferrari has winged doors in the exhaust that only open above a certain RPM :D
And other manufacturers cars might sounds loud under load, but remember... and this is what you are forgetting.
The test is done without load.
You know, f**k it. I am buying the apexi com.avcr boost controler,injectors,turbos and going to produce 1000 horses at the fly wheel..
Bring it on epa....
If Australia can sell coal overseas, stick their fingers up at all the other countries of the world and
refuse emission targets set ,so will i...
Im gonna make noise and consume lots of fuel doin it ....
f**k i just sounded like an American.....
See or chat to you later
  • Replies 50
Bring it on epa....
thats the spirit, no point trying to be green/clean when the government doesn't act the same way :D
They enjoy selling all the coal they can and using for coal power plants, without any concern for the Kyoto treaty etc...so why should we get worried over a few high emissions?
  • 7 months later...
Ahhhhh memories.
I remember when I first bought my car and was scared to mod this and that. I was worried what would happen if I was caught and how much it would cost. At the end of the day on a forum like this, if you ever do get caught there are always people willing to help, just ask Maverick.
All I can say is KEEP your stock parts, don't sell them. If you ever do get caught just wack them back in :banana:
Happy modding :action-smiley-069:
^ what's the point of that? if what ash say is right, (new laws, even a stock GTR can't pass)
ok, we'll now rev to 5100rpm
oh ok, let me just set that on my fancy shmancy rev limited, there you go 5100rpm
right o.... fail. next.
are you saying that they won't be able to rev it passed 4K? that will be pointless as they will know there is a restriction somewhere, find it, disable, and continue with the test.
kyoto is waste of time without everyone involved. don't wait for stuff like that, do it yourself. Join green fleet, change your light bulbs, get solar panels, use more public transport, car pool when you can. Plant craploads of trees. Don't chop down ones you have. Turn off any appliance you don't need on, standby modes use almost as much power as machines being on, etc, etc...
sad fact is, without countries like china/india involved, kyoto is worthless
EDIT: so Dr Drift ECU tune is illegal?
you really are a straight edge...
You didnt know the bee r shoots flames and will singe the eyebrows off the epa blokes?
Or
Are you all defensive about making fun about things?
When it comes to epa im all for passing etc.. But who can be fooked honestly
ofcourse
Technically they're not illegal as they are not 'user tunable', just require a full emmisions test to prove they meet relevant ADR's, in the same way that any password lockable aftermarket ECU can be passed.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
