  • Replies 50
Until the ECU cover is opened... like they did to my car :)
Then regardless of the 100 other things, your gonna get pinned
No traffic cop is gonna sus you out for a chipped ecu.
If your being sent to the EPA for testing....I assume you would return most things back to stock - including the ECU. If its been chipped buy a stock ECU for 30 bucks I see them all the time. If your really worried buy a backup ECU when u do the upgrade. PFC users should keep their stock ones for this purpose.
Thats my point.
^^ I have been there many times and asked the guys if it was ok before it was done, then when I told them it was done they barely even blinked. Mind you everything else on the car was fine whenever they checked it. Also I have only seen two guys there?
Edited by stolen_s15
so why weren't they worried about it with stolen_s15's car? ;)
No idea, who knows what they discussed as its totally inaccurate.
Ask the EPA and you'll get the answer if you dont believe me :laugh:
Although, FYI... it'll be exactly what i said
HWT Tower
Podium Level, 40 City Road
Southbank Victoria
Telephone: (03) 9695 2722
oh, don't doubt at all that what you say is the truth. I know a chipped ECU is illegal, just wondering if there's some leniency they're showing now, in regards to chipped ECU's or something like that.
Once i've got all the performance bits i want on the car, i'm going for a Dr.Drift ecu remap, i know it's illegal but meh... my exhaust is very quiet, otherwise i have nothing really to be picked up for EPA.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
