yep that sounds about right. and it isn't a good idea to change it to any higher if you change ecu's. if you were to take it to 7500rpm you add about 1500-1700kg of load onto the conrods.
Huh, HPI reader (or was it Zoom). MD as usual didn't tell the whole story, I think he loves dropping a bomb then walking out.
:O cheers :D
:O cheers :D
BAAAHAHAHAHAHAHAAAA!!!!!
Snap!
I raced for AGES on a 7600rpm limiter before the nitrous.
Adrian
7150rpm puts the RB30 piston speed at around 4000ft/min, which is around the most you would want to push a standard production motor too. (Without a full prep, balanced, lightened internals etc to the engine)
Sure you can go more, but the 4000ft/min is considered a practical safe standard limit!
