Rattle is not “brand” dependant. Most of the brands have “competition” multiplates that rattle and “road” multiplates that don’t. The difference is the “road” ones have bevel springs on the clutch plates and the intermediate plates, that press against the cage. This stops the clutch plates and the intermediate plates from rattling when there is no load on them. Obviously the “road” multiplates cost more as they have more components. Plus they seem to charge more than parts cost, just because they can advertise no rattling as a benefit.
:D cheers :wub:
just wondering after all the discussions on twin plate clutches, ive heard some brands dont rattle at all when u press the clutch in.
ive been told the nismo ones dont rattle is this correct? and what other brands are the same?
i can tell you for sure that new nismo ones can definetly rattle :)
We run an OS Giken twin plate. It came with the car and I dont know if its got solid or sprung plates but its like a switch. Ive run a load of clutches including other OS twin plates and a range of paddles and this is genuingly like a switch. Quiet though, no rattling.
Anyone running an ORC? Theyre good money :thumbsup:
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
