Hi everyone,
my master brake cylinder sprung a leak, so i ordered a rebuild kit from nissan. I gave them my vin number etc to ensure they got the right one.
anyways, the parts arived today, and as soon as i pulled my cylinder apart, i noticed they were comletly differant!!!!!!
a quick search in the shop manual showed me that the r32 gtr cylinders had 2 differant manuafterers, tokiko and nabuco(nabco).
according to nissan and also fast, my gtr was supposed to have the nabuco(nabco), cylinder, but when i looked at my one its the tokiko cylinder!
does anyone know if the two are interchangable? the look to be the sane diameter, and the master cylinders look the same, but the secondary cylinders are differant i.e the o ring more forward on one.
can anyone offer some adivce??
thanks
steve
Edited by PHATR32
f**k me, i was looking at the r33 shop manual and found out exactly what is what.
so i guess i just have to find a brake cyl for a abs r32 gtr, it looks like the stooge that owned my car replaced the master brake cylinder with a non abs unit, which i assume caused it to leak.
steve
Edited by PHATR32
come on guys, does anyone know what the deal is with the tokiko master cylinders?
i though my one was fitted on buy one of the previous owners, but reading another post i saw another r32 gtr with the same cylinder.
problem is nissan gave me a part number from a differant model cylinder (after looking up my VIN)
any help would be good!
steve
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
