I have this whining typenoise coming from the front left of my engine bay
I think it could be either the power steering pump or the air con compressor perhaps?
Anyone have any idea?
chris
does it do it all the time chris?
Mine used to make the scraping noise when turning, turned out to be a ps pump leak (low fluid)
Now it makes a scraping from the same area only when the aircon is switched on. I need the aircon compressor rebuilt (new bearings, maybe clutch as well)
Yeah, I think its the air-con, as I have been using the de-mister quite a bit recently, it gets louder with this on
You reckon thats what it is? After about 2 mins its almost not noticeable, when I start it, its louder
PS Fluid level seems ok
could be. Drop in to an air con place and get someone to have a quick squizz is the best bet.
There is also the aircon belt adjuster bearing under the front left, which mine was making some noise. stick yer head under and have a listen if its that as well..
If you think its the air cond pump, disconnect the belt and see if its quiet . Power steer pump would be noiser when under load, like when you are turning the steering especially on full lock.
Had a more detailed look last night
Definatley coming from the aircon compressor, and a bit of noise coming from the adjuster pulley as well
How do I remove the belt? Looking at it, I'd have to remove the power steering pump belt as well to get it off?
Thats what I am trying to find out!
by the looks of it, its just a matter of backing of the belt tensioner and slipping the belt of the compressor, but to get it out, it looks like you have to take the power steer pump belt of too
Trying to find out a answer before I dive in and give it a crack
If it's anything like the R33, then yeah, the belt comes off after you undo the LOCKING nut, then undoing the tensioner bolt.
From there, the AC belt is closer to the motor than the psteer belt. (on the harmonic balancer) so you'd have to do the same process to get that belt off so you can completely remove the AC belt.
On the AC, the locking bolt is the one facing forwards, at the top. you can get a socket onto it through one of the holes in the pulley. Without doing this first, the tensioner bolt shouldn't budge.
Might want to post pics, and then we can confirm. I still think it's strange how people buy cars with all the good bits, then remove them (hicas, AC etc) =-[ On the racetrack, I understand, but for a daily driver... =-o
The reason I want to take it of is to see if it stops making the noise first. Anyway, its winter, so I can get my aircon fixed well before summer comes around
All fixed, turns out it was the aircon tensioner pulley
Replaced it on the weekend, and it sounds fine now.
Interestingly enough, when I took the old one off and comapred the two side by side, the bearing in the one that came of the car felt reasonable, I showed my dad and he said to spin it with some load on it, and sure enough you could feel the bearings grinding away!
Very happy, was easy to do as well!
Chris
Yeah, I asked the guy at the wreckers about that, he said that most people end up damaging the pulley. I might have a crack with my old one, and if it works, there will be a pulley with a new bearing up for sale
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
