I have this whining typenoise coming from the front left of my engine bay
I think it could be either the power steering pump or the air con compressor perhaps?
Anyone have any idea?
chris
does it do it all the time chris?
Mine used to make the scraping noise when turning, turned out to be a ps pump leak (low fluid)
Now it makes a scraping from the same area only when the aircon is switched on. I need the aircon compressor rebuilt (new bearings, maybe clutch as well)
Yeah, I think its the air-con, as I have been using the de-mister quite a bit recently, it gets louder with this on
You reckon thats what it is? After about 2 mins its almost not noticeable, when I start it, its louder
PS Fluid level seems ok
could be. Drop in to an air con place and get someone to have a quick squizz is the best bet.
There is also the aircon belt adjuster bearing under the front left, which mine was making some noise. stick yer head under and have a listen if its that as well..
If you think its the air cond pump, disconnect the belt and see if its quiet . Power steer pump would be noiser when under load, like when you are turning the steering especially on full lock.
Had a more detailed look last night
Definatley coming from the aircon compressor, and a bit of noise coming from the adjuster pulley as well
How do I remove the belt? Looking at it, I'd have to remove the power steering pump belt as well to get it off?
Thats what I am trying to find out!
by the looks of it, its just a matter of backing of the belt tensioner and slipping the belt of the compressor, but to get it out, it looks like you have to take the power steer pump belt of too
Trying to find out a answer before I dive in and give it a crack
If it's anything like the R33, then yeah, the belt comes off after you undo the LOCKING nut, then undoing the tensioner bolt.
From there, the AC belt is closer to the motor than the psteer belt. (on the harmonic balancer) so you'd have to do the same process to get that belt off so you can completely remove the AC belt.
On the AC, the locking bolt is the one facing forwards, at the top. you can get a socket onto it through one of the holes in the pulley. Without doing this first, the tensioner bolt shouldn't budge.
Might want to post pics, and then we can confirm. I still think it's strange how people buy cars with all the good bits, then remove them (hicas, AC etc) =-[ On the racetrack, I understand, but for a daily driver... =-o
The reason I want to take it of is to see if it stops making the noise first. Anyway, its winter, so I can get my aircon fixed well before summer comes around
All fixed, turns out it was the aircon tensioner pulley
Replaced it on the weekend, and it sounds fine now.
Interestingly enough, when I took the old one off and comapred the two side by side, the bearing in the one that came of the car felt reasonable, I showed my dad and he said to spin it with some load on it, and sure enough you could feel the bearings grinding away!
Very happy, was easy to do as well!
Chris
Yeah, I asked the guy at the wreckers about that, he said that most people end up damaging the pulley. I might have a crack with my old one, and if it works, there will be a pulley with a new bearing up for sale
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
