R33 Rb25det Gearbox
Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
No clips on this one like the other connector. Only that red tab that I can push slightly up.
For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
