R32, 33, 34, S13, S14, S15, Wrx Leather/vinyl Seat Covers..
Jetdat
 Share
  • Replies 215
Posted Images
Seats look good ali-turko!
Also, if you are going to order these seats, you have until the 22nd of July so only 2 days left for payment! Be quick! These offers won't last
lol - I should do ads, how good does that sound? haha! Anyways, serious face now ..if you want these covers etc please do get it by the 22nd.
Is it too late to modify my order ?
Now I'm going to need a DIY thread to help me figure out how i pull out my rear seat's for the new covers, same with taking the handbrake boot off,
Anyone else going to be struggling to get there new interior in??
Anyone in Adelaide that's getting a 32 interior and thinks they know what they are doing can lend a hand if they want. :(
magik32
its easy as mate, run your hand along the front bottom of the seat where it joins the floor, you will feel towards the ends of each side there are 2 clips, pull them up and they will unclip,
then pull the seat forward and it will come out
Undo the 2 bolts on each side of the back part of the other seat part, push it upwards towards rear windscreen and when its at the top pull forward and it will come off the clips....
hard to explain but easy as, shouldnt take longer than 2 min
ed
sorry for the late reply but i think it is the same place as where u guys are getting urs (in dandy)? and the seat covers are easy to put on if i new the just tied on i would have put them on my self
Yeah, same company based in Melbourne. The seats wouldn't be too hard to fit, the problem for most people will be the door trims etc, reason for this being they may have to be professionally fitted because they may need to be heated on to prevent wrinkles 6-8mts down the track.
  • 1 month later...
for anyone with a 4 door R34 that got fronts only, I have now pulled the oem fabric off my rear seats (bastard of a job) and am sending them to UAS to make some rear covers for me - so they will have the template to do it for others.
The oem covers are GLUED to the foam, so you have to rip, tear and bust to get them off :yes: .... didn't go too badly though .... and since the oem fabric goes back on and the leatherette covers go over the top, no-ine will ever notice what I did to the foam underneath.
  • 2 years later...
  • 1 month later...
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
