Most of you know about the huge issues I had importing my GTR and a importation story which is best described as an absolute joke. Long of the short, the car finally arrived about 9months after payment not as described but it did have additional damage thrown in for no extra cost.
Well more than a year after I payed for the vehicle and all costs etc I get an envelope in the mail from the logistics company involved in clearing the car from customs etc.
Guess what? They forgot to bill me for additional costs (steam cleaning etc) at that stage and now more than one year later are threatening me with legal action for a invoice they havn't given to me till now!
pfft yeah riiight.
Someone kill me now and put an end to this!! No prick ever is getting a cent out of me for importing this car. Over my farkin dead body.
Hey mate, where you hiding? Who wants the money for the car now?
dunno if I can say the name but all information posted is factual - Seaway Logistics.
They set 7 days for payment and I got the letter on the seventh day. I want to see them take this one to court and tell the judge they've billed me more than one year later and demanded payment.
Sent an e-mail to a reply from one of their employee's this morning but received no reply. (i asked to speak with one of their managment)
I also copped an additional invoice from my clearance company about 3 months after the car was imported for steam cleaning. How it took 3 months to establish this is beyond me but I coughed up as it was a friend of the family who owned the clearance company. Know how you feel though. :D
hmmm that sucks. seaway were fine with me, except for the slight hold up with the car in brisbane...
after that it was all good, and the chick i dealt with in emails and on the phone was extremely friendly...must've wanted me because I had a SICK SKYLINE!!!
jesus.... does seaway ever stop f**king up?? They f**ked up my invoice but it was rectified, Since then I've recived numerous PM's from other people with similar problems not to mention what I've read on the forums!!!
IDIOTS!!
Yeah
I copped one from seaway last week demanding one for towage and stuff call Melbourne office and ask for Craig McElvaney he should be able to sort it out for you, if you explain the situation (if you can get hold of him that is) 9 months after the fact is crazy
Failing that [email protected]
haha sounds a bit suss to me ..
like a passive hit and miss rought...
I would call there bluff on it as that debt collect letter's are just fancy stationary unless the debt is in the thousand's when you would recieve proper legal documents to go argue the case.
Edited by ishh
I would tell that since its been so long, you don't believe that they had the work done. I'd pay it, but ONLY when they procide to you ORIGINAL documents to proce that the work has been done. No proof the work has been done, no need to pay.
Yeah - and get management involved too... make sure you take up LOTS of their time. Make sure they are aware that you have a problem. Managers are usually busy (believe it or not), and their time is valuable. Take the time to make your position crystal clear.
Also, find out what the law is. I doubt they would take you to court (small claims, I guess), but I'm not a lawyer. Are they allowed to bill you 1 year afterwards? I think if you called the ACCC you might be able to get some legal advice.
Keep us posted (posted, get it...)
from there own website
The Seaway Group of companies is privately owned and was founded by directors Peter Wallace and Craig McElvaney in July 1999.
The Directors of the Company are Peter Wallace, Craig McElvaney and Paul Szumowski
you carnt get too much higher than the contact i gave you just keep at him
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
