Awesome work by the twinky mitsu!
What I want to know is how it is driven to and from the track without a radiator :D
Alcohol, Charlie :wave:
Kenny, The link in the original post may be accessed by clicking the little button on the left of your mouse. Easy, see? :D
https://www.sau.com.au/forums/topic/124300-holy-goodnight/#findComment-2303203
i havent looked at the link yet, but it would be john shepards super quick mitsu talon.
it used to run in NHRA sport compact class PRO STREET against the titan supra. but he decided to take it up a notch and is running slicks now and a bit of weight reduction. its still a manual box and he uses the clutch to change gears unlike some people here in australia
oh forgot to add, he seems to now run only in puerto rico, they mainly just match race.
if your into drag racing check out agracingphoto website, or the hardcore pr site, theres heaps of awesome stuff on there.
Edited by 1JZ.747
https://www.sau.com.au/forums/topic/124300-holy-goodnight/#findComment-2303422
It reads like a Spanish -> English translation but:
" The man behind all that is John Shepherd the same that years ago intimidate the Street tire class some years ago, but like always every true racer have the same trouble in satisfying themselves and John have that problem too. Because of that he are in continues changes looking to beat himself every single time gets on the track. Other good things in this project are the determination and perseverance that have John with the same car and how he always fined new things to get the car faster and stronger especially in the drive train the weak link in every AWD except this one. Shepherd make himself the best technician Mitsubishi Trans. in US maybe World Wide and the 7.97 @ 179 speak for him. "
https://www.sau.com.au/forums/topic/124300-holy-goodnight/#findComment-2303485
Touchy, touchy! OK, I get it now. A race car ran a high 7, cool.
No, a 2500lb, street driven 4 cylinder car ran a high 7.
FFS, it has a manually shifted box - I thought you would've pulled the end off one by now, Kenny?
:D
Adrian
https://www.sau.com.au/forums/topic/124300-holy-goodnight/#findComment-2303583
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
