I took my turbo smart boost controller out bcoz the police told me to otherwise its a $300 fine.
Just wondering does the boost controller have to be in the engine bay?
Can I install it under the dash somewhere and run the line into the engine bay into the actuator.
Or is the length of the hose critical that is connected to the controller and actuator?
Also my Autometre boost gauge always needs calibration after 3 months or so...which means i have take it out of the dash and pull the dash apart to get in behind it to calibrate it. Any suggestions or similar problems.
I Also need an air box made up to fit around my Blitz pod filter. Any suggestions in Sydney?
lol suprised the boys in blue knew what to look for, havent got one but a few mates run them and havent had any trouble as yet , i thought you could get in car digital ones that you could up and down at a push of a button
in both cases, electronic or gated, you can run a hose into the dash.
a 2m or so added length to the hose wont affect the performance etc..
turbosmart sell a 2 stage in cabin unit, which has vaccum lines from the wastegate to the cabin, then to the manifold. that short of a distance should do nothing
my waste gate has one tube in the middle of it going to the intake manifold but it also has a connection on the back of the wastegate for another tube where would this go to ?
is it an internal or external gate?
ok 4 sum reason i cant upload, so il try n explain it.
the top pipe goes to your solenoid, and the other pipe goes to a "t" peice. this then goes to the other side of the solenoid and to the manifold.
comprende?
comprende?
yeah i understand ,the top one on this goes to a T which splits it to the boost gauge and to the manifold the one on the rear of the WG doesnt have a pipe going anywhere just the fitting
The less hose there is between the bleeder the better.
My bleeder was very close to the turbo for a while, not a spike.
Ive seen other "in cabin" jobs and they are appaling.
Either way, the police these days are not stupid (i assume you are in Vic)
I would just take the car to a workshop and have the actuator modified to run a higher boost level for minor applications
I was told by a cop to remove my ebc one day, i rang transport and they said it was fine.
Called the cop back and left a message to call me, suprise suprise he never called me back.
I am in qld, dont know about victoria though.
I would never use a simple bleeder, grab a pfc and the boost control kit for that. You should be able to hide it pretty well!
Whats wrong with using a bleeder?
Dont know what experience you have had with ebc's but mine have been all good.
I wound never use something as cheap and coarse and a bleeder i also like the ebc's ability to bring boost on a little faster!
If the budget allows i would always grab a ebc, but yes there are some out there that are a little dodgy.
I have used profec b, and profec b spec II, for my 26/30 i will use a pfc and the pfc bc kit.
Well see how it goes.
However i will be the first to admit it can take some time to set an ebc up perfectly!
If your labelling a bleeder dodgy, you have NFI what you are talking about :D
I've never used an EBC. Bleeders since day one.
EBC's are nice, bleeders are nice.
To say one is dodgy is just wrong
As i said i feel they are a little coarse, and cannot bring boost on earlier as a ebc can.
I also said that some ebcs are a little dodgy, does this mean i have NFI what im talking about?
I suspect that it people are having problems with ebcs that are known to do the job well then perhaps they need to look at uprgading from the stock actuator to bring their mechanical boost level closer to their desired higher ebc boost level.
i dont reckon an EBC can bring boost on earlier compared to a bleeder.
I certainly didnt have boost delivery issues
With an ebc you can adjust when the wastegate starts to open, this brings boost on faster than a bleeder. If you set this to close to your desired boost level if will spike. You must find a good compromise which is the difference between a well setup ebc and one that isnt.
The greddy profec b spec 2 can also limit boost spiking. eg i have it set to 1.18 bar as i dont want it to go over 1.17. This feature is really handy when setting it up.
Maybe give one a try someday, you could always sell it if you dont like it.
If you have a pfc i think it would be silly not to run their pfc ebc kit.
Also i wasnt saying you were having boost delivery issues.
Mick
EBC vs a Bleeder, I have a Turbosmart boost Tee I have no problems with it, if you hit the Accelerator hard a 5000rpm it spikes only .5 psi and it is conected after the coola. is spikeing all that bad, $80 to $400 I think the Bleeder does fine.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
