ive done this - well for no reason the boot buckled causing one side of the spoiler to almost detach. Soooo undid all the bolts i could see holding the spoiler on then came the good stuff - trying to prise the sealant apart without scratching you boot or damaging the wing - it takes patience :D
  • 1 month later...
If anyone has those pads that some people have between the spoiler and the boot, and doesn't really want them, I would gladly take them off your hands...
Thats the only part of the car that rattles with bassy music...
I'd love to finally get rid of that thing as its quite noticeable from inside...
Anyone know what I am talking about or can help ?
Hey.. i dont know if this is what would help you, but a friend of mine and myself fixed his whole front bar(LARGE veilside bar which was half hanging off a swift gti and vibrated stupidly) by using rolls of stick on foam/felt. U can get this stuff from say clark rubber or autobarn, or even a hardware store.
U stick this between anything that might vibrate before u put everything together, it worked really well for us..
siksII - I was thinking of something like that for ages now...
The only thing that stopped me was trying to get the wing off...always afraid I'd rip the paint off the boot...
after reading this thread I am tempted to try it...
gonna take the bolts off and lightly lift to see what happens...
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
