i was just surfing the net and saw this mint yellow R34 that was previously in sydney but now in perth.
check it out http://www.cardomain.com/ride/339944
i wanted to know if this guy was apart of this forums as he listsed it as one of his Fav links.
cheers
https://www.sau.com.au/forums/topic/124438-who-owned-this-yellow-r34/
yeah thats Frankies old car, he used to be around SAU all the time, kinda disappeared when he down graded to his new car (a hummer i think he moved to the states)
I did a couple of laps of wakefield park in it, it was a good car, well set up suspension.
Hope whoever has it now is enjoying it :D
Hey Akeenan can you plz have a look in the nismo catalogue on how much they are? Ive been trying to chase down one of these for ages with no luck. Only other place to buy the oem wing and the uprights are carmate, trying to find one cheaper. Need a new wing to replace the huge factory ones.....
リアウイング用ステー
R34 2ドアクーペ専用
角度調整機構付、ウイング部分は純正品を使用して下さい。
ステー:アルミ製黒アルマイト仕上げ
マウント:FRP製黒ゲルコート仕上げ(要塗装)
96030-RNR40 ¥65,000
For the R34 2 door coupe, angular adjustment mechanism which attaches to the original rear wing. The mount is made from a black alumite gel finished aluminium mount. FRP black gel coat finish (main point paint) 96030-RNR40
YEN 65,000
pretty damn expensive just to hike up the rear wing a bit.
oh heres a link to a pic
http://www.auto-style.jp/nismo/index_page....=NSM20231420001
hahah that yellow peice of shit !! :(
I bet Franky will pop up out of no where and reply to this like he always does !
Nice car, looks good, and as duncan said the suspension was well setup.
Full whiteline kit with tanabe lowered springs I think.....
Duncan, he WANTED to get a Hummer but last I heard he was putting around in a work issue SUV or something, he is in NYC now and has no need for a car.
Will be coming back later on in the year and has something up his sleeve for the sau boys ;)
thanks for the heads up shonen! i would'nt have found this thread otherwise! :whistling:
heya all! some familiar faces here! :) erik (of course, the sucker who bought my car hehehe j/k!), mr wakefield himself duncan! nick aka pin up boy for sau! =)
good job on the research akeenan, yup, that looks to be the part for the wing. unfortunately with imports you dont quite know what to expect! :pwned:
that was a top car, only thing left was to squeeze more power out of it but i didnt quite get there and neither did erik, maybe dr_mafia will! that car was brought in as is with the exception of the front bar which was replaced with the top secret copy (and all the hypo bits of course which was all part of so called my "investment")
this is what it looked like originally from japan, that front lower lip (all beit with a terrible paint match) lasted all of 2 weeks before succumbing to a petrol station driveway where it just completely ripped off! =)
http://www.markpakula.com/~franks/gallery2...?g2_itemId=2290
dr_mafia, what do you have installed for its 3rd generation in oz!!! :blink:
hahah no i dont have a h2 hummer, although i wish i did! i just rented it whilst i was in miami =) the h3 will be in oz in 2007 anyway! my only association with cars these days is with the r/c kind ie. my tamiya =) that'll change soon. back in oz by december!
Edited by franks
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
