  • Replies 52
Posted Images
you should leave the inlet manifold one hooked up. (pcv valve)
the turbo side should have the big one from the rocker cover going to it and thats it. simply block the suction pipe hole and leave the little filter on the can.
The T Piece runs to one of the inlets on the catch can. It used ot have two lines to it but then i couldn't have a breather (as the catch can didnt have one built in) so we used the 2nd inlet on the catch can and stuck a breather on that, but i am thinking that doesnt work... lol
Car only blows alot of smoke when you have put ur foot down into boost, on idle its very minimal
Some smoke comes out the rocker covers but when the catch can system is disconnected the car blows alot less smoke out of the exhaust system...
Im off to buy a decent catch can and see if that helps peeps!
Otherwise i think theres somethin else wrong aswell... maybe an oil drain/inlet problem?
I'd have to agree with the rest, That line off to the catch can is probably too restrictive and is causing the crank case to pressurise, when the crank case is pressurised the oil drain backs up and pushes oil out the turbo seals. happened to me when i had a retard attack and tried to use a hose and very restrictive brass air filter for my vent and had the same thing happen with my brand new garrett turbo. :(
Ive disconnected one of the lines that runs to the T piece and then to the catch can and the car seems to blow very little smoke now, still abit but about 90% less!
So obviously i need a better catch can set up and ill check the drain lines etc anyway on monday. I should be able to keep off a defect now tho :(
you basicly need to hook it up so ideally you would have large catch can with 3 fittings or 2 fittings and a vent.
two fittings for both rocker cover hoses.(the big ones)(plug the pcv valve)
and the thrid to atmosphere or back into the suction pipe :(
I will sent two hoses to the catch can and have the breather ontop of the catch can :(
Im still getting a tiny bit of smoke but im sure after the lines are looked at and the tuning plcae get it we can sort that out!
Thanks for the help so far peeps.
I don't understand how restrive lines or bad catch can - can cause that much white smoke -
I'm not saying this wasn't the case - just trying to understand the physics behind it - As I had a similar problem with my old car.
In my case the air intake route was blocked off, so all the bad oils etc have nowhere to go except to the catch can from the head. If the lines are too small or there is a problem with the breather then pressure can build up and force oil out in my case through the turbo's oil seal i believe?
The system needs to be able to expell the gas's and extra oils that build up in the combustion process basically...
have you taken one of your intercooler pipes of to see if your intercooler is full of oil?
The intercooler had a slight build up of oil but nothing outta the ordinary. The wierd thing was oil got into the boost controllers actuator line! That messed with my controller but i let it out and pulled a line off the block and it runs fine now, i have to keep it like that until i get the new catch can next week because if i hook it back up it'll cause the oil problem again! As it is its not too bad at all.
Ok i replaced the catch can with a better set up, two lines running to it and it has a built in breather and i still get oil smoke....
Next up i will have the turbo oil line looked at to see if it has a restrictor on it otherwise check the line to the sump isnt blocked.
If its not that then i guess its the turbo oil seal??? :D
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
