  • Replies 128
Posted Images
when over to kamikaze today and i dropped off the oil to them. planning to get the car on thursday morning if i can and rego and then full body check up.
Met Craig from Jspec today and he saw the car as well. You guys should have seen his r33!!.His rear tyres are bigger than mu butt. LOL!!
soz i used my younger bros username it was me who post the reply.
yes uts the red one ans he (craig saw my car as well. He passed me the spare key the remote for the alarm and the manuals for the car why?
Well i need to get it regoed @12.15pm so.. i dont know what time will that ends. I will be getting the car into racepace hopefully on thursday after the reistration, say @2pmish. It all depends on the registration really. I cant give a definite time.
Depending on who you get at Vic Roads it could take a while...
I was there for more than 2 hours while they worked out what they needed to do, after I waited a week for a "high risk" appointment!
Fun!
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
