I've thrown the pfc in darrens and it does the exact same.
When darren brings down his stock ecu I will find out what else is gone in mine, hopefully nothing but apparently its common for the ignitors to go.
Hmm it doesn't sound too good. But it is possible that it's fixable.
That diode that you found is the main power protection diode that all cars have to have in their ECU. if you reverse power the computer that should take the full brunt of it to prevent damaging everything else. It is possible that it is damaged without it being burnt, & could be stopping the whole thing from running.
Is there anything actually working on it at all? It could be this diode if that's the case.
Also that does look like a blown track on the TPS power feed are you sure it's the power feed though. Is there exposed copper at either end of the break? If so yeah it's been zapped & needs joining back up.
Sorry I forgot to update this thread. >_<
I sent the PFC in to force electronics, they checked it out and replaced various resistors and capacitors.
It now works PERFECTLY!!!! :sick:
RE: Pin 57, that is indeed a cut track as Bl4ck32's AP Engineering PFC also has been cut.
After a little investigation it appears the R32 pfc is based on an early r33 pfc. Pin 57 on the R33 is an exhaust heat sensor, where as on the R32 it has something to do with throttle input, apparently used in the auto's.
So AP have cut the track to be on the safe side it appears. :D
Somewhere like Petroject would have been my first choice. These guys specialise in repairs to engine management systems & are more likely to be able to help you to diagnose the problems with consultation & having electrical information of many vehicles also enables them to figure exactly what circuitry has been damaged etc.
They also have a special test bench which enables them to actually run the ECU & check what's working & what's not etc. They deal with a lot of the trade & the guys there have a lot of experience between them. Most of the time the only reason things can't be fixed is if they don't have spare parts for a special component (eg a main microchip), or the board is too fried, or if it's simply uneconomical to fix.
For the kind of repair you needed done you could get away with going to Force, but if it had become any more complex than that I doubt they could have done it.
Edited by Electro
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
