its the reverse placebo effect.
there used to be the problem on the board, hence this topic, but its since been fixed. however some people dont realise its been fixed, and hence are thinking its somehow still happening :(
God I hope so... I've had enough of working on SAU to last me another 6 months, and I'm still not finished. :D
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2302766
  • Replies 95
Fingers xed... I saw the boards down today at work, logged on later in the day no problems.
Just logged on at home (11.28pm, 3/7) and I had the exploit blocked (I'm hoping from a locally cached version of the page, but I haven't logged on from here for a week?)
Anyway, I know you'll still be monitoring it - just thought I'd let you know.
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2302820
it will be a patching problem not entirley on the IVB side. Wait for dicrosoft to patch it properly Ie wise and Ivb to run out the kink's i bet over a few weeks . IVB the will be still very worried about it and a few features will no doubt be not functioning for saftey ! .
Microsoft let out a Doossie with one of there upgrades that found pirate copies of Xp . since then alot of people are unpatched and there are lots of conflicts.
Edited by ishh
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2302830
No, haven't received it before... Was only reading about the Billion boards being affected by it this morning, didn't even blink as to why the SAU boards were down (stocktake was a b!tch.)
Silly me didn't check the timestamp in the temp file before it was removed... I've reloaded the page & IE many a time anyway - hasn't reappeared.
Who knows, peculiarity of Apache or one of the various proxies I'm running through I guess...
(Edit: Ugh... bloody thing is still running, back soon.)
Edited by cooks44
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2302902
Got it today at work after the site had been down... and just got it now at home. Each time my McAfee seems to have caught it, although there is a HEAP of HDD activity for quite some time and the computer slows down... (and no, I wasn't running a virus scan)
So something still creepy in there guys,
M
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2302952
The reason this security alert comes up is because of an exploit used on IE.
This utility released by Norton (antivirus software developers) can be used to disable windows scripting... if at any time you find that you need windows scripting enabled (if one of your apps won't work) you can use the same utility to re-enable it.
http://www.symantec.com/avcenter/noscript.exe
Its recommended that you turn off scripting so that no malicious websites or people can force your browser to download and run trojans/worms.
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2302981
this is more an exploit being found By your Av than Trojans loading off the SAU Page slowing down your systems hard disk.
It doesn’t mean that a Trojan is loading ... It means it has vulnerable scripting and it is possible.. < this is the message to get out !
I highly doubt that anyone got infected as it was just a generic warning from the AV reading the scripting.
Prank i would try to word a statement that states it is the vulnerability that has been found, Detected by AV not a virus or Trojan.
I am Guessing a bit there because i don’t know if anyone got infected but that’s my guess in the confusion !
For someone to achieve this they would need access to private FTp to embedded the server or an identical mirror linked with the embedded server.
Most members would have this Short cutted so the mirror would not work either.
If by the slightest chance it was mirrored then its going to jag non members surfing from an engine.
Tell the whingers that it is there old Av update that is detecting the Script.
and to please be patient.
if you can Categorically state that nothing dloaded from the page and infected anyone then this will help out a lot with the complaints you may get....
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303336
GET FIREFOX or OPERA instead of the IE browser.... ITS not the SAU board, its because the SAU board is Invision and Ie has a big hole in it ... the same will happen on any Invision Board using an Ie browser until Microsoft do something .
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303398
Hi guys,
Just in case it helps, the offending file that McAfee pointed at was called 0day.htm
This file goes to http://196.regvista.com/0day.htm
Maybe this would help to sniff it out?
Immediately after McAfee finds it and cleans it, McAfee is disabled! And there is a c$#@load of hard drive activity for several minutes..
Cheers,
Matt.
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303417
yeah i got the trojan downloaded to my home machine over the weekend. i removed all the crud using adaware but my pc is now a bit fuxored unfortunately. AVG is broken so i've tried uninstalling it and installing norton but cant get through the install without it dying. :D
anyone got any advice? :P
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303473
I thought it had gone, but alas, I just got another warning from my a/v (Avast pro).
Seems to identify it as WIN32 Trojano ...
My a/v catches it and terminates connection before there's any consequence.
This only happened for the first time on Friday I think.
Has never happened before, so I cant imagine, as previously mentioned by someone, that it's Invision, unless SAU has just changed their system over.
Also, had no old cache, i clean it almost daily, and IE is set to load new page everytime (no caching).
Anyways, not a big deal on my end, but perhaps might be helpful to track down the issue.
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303490
i am looking at all the manual ways now....
... For a try install norton in Safe mode ... Or systems restoring before hand and repeating...
Looking into this more now I see its a fairly old exploit reworked . So until more info unfolds its a bit hard.
F8 key hold down on reboot until you get Safe mode ... then run the the install. Its tricky because you have to some how get the Av to update in safe mode
My AV rips it straight out !!! Pm me if you would like to try it .
Munkyb0y Av only finds it once its been reported. the exploits can function and go on for months before this!
Edited by ishh
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303497
This is not an option for me
cheers.
Hi guys,
I just got the identical thing.
I've been browsing SAU for 4 hours now (from the uber protected work PC). And the Norton box just fired up @ 10:44 with the same above ^^^
I've flushed ALL the temp files etc etc etc.
And ive just done it again.
Will report back if it get it again
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303506
Hello again.. this is a test
I am using ie 6 NO AV and nothing is connecting , Downloading or Executing .
As i mentioned before to Munky these exploits are oftern not reported for months so everyone is oblivious until there is an Alert.. Then poo fly fanward forth!
this ie exploit can be used so braodly so i still think the Sau board is fine now upgraded and more the users buggy infected Pc's ,its just that this situation Alerted alot of people that they had a problem....
For all the people with Disabled AV Try this link to actualy see what state your PC is in. Not sure if the demo will clean it! My guess is it will :D
http://www.trendmicro.com/hc_intro/default.asp
Ie is Every uni students wet dream to practice code on .... Its also the most cloaked process giving people the impression that its fine because its always running . DANGEROUS
I am still working on the manual removal... It would be good to look at the old unpatched pages ???
Bac soon ish!
https://www.sau.com.au/forums/topic/124535-trojans/page/2/#findComment-2303636
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
