  • Replies 95
Yeah, still happening.
The work pcs AV is finding some trojan soon as I click on the site and then the whole pc freezes up.
It made the home PC have a heart attack and would not let IE stay online for more than 30 seconds so formatted the thing.
Came back on just now and when I open a page it then says its opening something else in the background called 196.regvista.com or similar and it then said its opening or starting applets or something. Im not PC literate so I have NFI if its bad or not.
https://www.sau.com.au/forums/topic/124535-trojans/page/5/#findComment-2316538
I am doing the best I can, we are narrowing down their entry into the code. I am working with the team at IPB to get it fixed.
Guys, please use Firefox if possible until this is fixed as the exploit is only in IE.
Christian
https://www.sau.com.au/forums/topic/124535-trojans/page/5/#findComment-2316654
Ah now hang on a min... you've changed it since i posted :thumbsup:
It was definately there @ 5:30pm
I was seeing the little extra "page load" in IE... but now im watching it its not doing it (last 15mins)
Ill press on, see if it happens again :wacko:
https://www.sau.com.au/forums/topic/124535-trojans/page/5/#findComment-2318629
This is one pesky little bugger. Please note, I am an accountant. I dont do IT and I in know way know what is techically happening. All i am posting is what happened to me.
As of yesterday 10 / 7 /06 about 4pm I opened Sau. As soon as i went into sau it opened up another Mozilla browser mirrioring the sau website and down the bottom said downloading information from regvista.com
I was in a Mozilla browser at the time. I did a virus & spam scan of the computer and it hadnt detected any virus / spam.
Was a bit scared as my cpu went into chug chug mode and slowed right down. I went to close both browsers but it wouldnt let me, then i went to end program on both browsers and it wasnt closing them even then. I quickly reset the computer.
I *think* this virus/mirror site etc CAN open another mozilla browser (as it definetly happened to me) but doesnt seem to be able to attach the virus to the computer.
Can anyone confirm that this has happened to them using mozilla?
https://www.sau.com.au/forums/topic/124535-trojans/page/5/#findComment-2320297
Guest PranK
Hi PurpleR32, Mozilla browsers may try to open it as the code is forcing any browsers to open it, but once opened it will only take advantage of a vulnerability in IE.
Does that make sense?
Either way, its been a while since we were infected as we made a few changes to the security and it looks like its working.
C
https://www.sau.com.au/forums/topic/124535-trojans/page/5/#findComment-2321242
C
Perfect Sense. It explained the reason why it opened up another browser and i didnt get the virus and why my anti-virus didnt go spastic saying it had detected something. However I still couldnt close ANY of the browsers at all. Only a reset / reboot fixed the problem
Thankyou for your hard work and efforts
https://www.sau.com.au/forums/topic/124535-trojans/page/5/#findComment-2321275
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
