MANWHOR3 Posted July 1, 2006 Share Posted July 1, 2006 Hey Guys I ran consult on my car and graphed the output of the 02 sensor under different conditions. My car has stock ecu, so it is untuned. On idle, it was basically sitting around 0.8v. It would oscillate between 0.75 and 0.85. Holding a constant speed of 40km/h in 3rd on flat ground had it oscillating around about 0.7(0.65-0.75). Does this sound about right? Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/ Share on other sites More sharing options...
paulr33 Posted July 1, 2006 Share Posted July 1, 2006 yep Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2300395 Share on other sites More sharing options...
Busky2k Posted July 1, 2006 Share Posted July 1, 2006 No. It should occillate between 0.0V - 0.2V and 0.7 - 0.8V. 0.6V is not 'low enough'. Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2300664 Share on other sites More sharing options...
T04GTR Posted July 1, 2006 Share Posted July 1, 2006 high voltage = rich low = lean in a nut shell Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2300718 Share on other sites More sharing options...
RB SANDY Posted July 1, 2006 Share Posted July 1, 2006 I have a drift ignite series air/fuel gauge and the needle does not stay still, when you are crusing at a constant speed and when you accelerate hard in goes all the way to ritch and you de accelerate it goes all the way to lean. I have a spare o2 sensor if I need to change it, or do I need a wide band o2 sensor. Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2300771 Share on other sites More sharing options...
Busky2k Posted July 1, 2006 Share Posted July 1, 2006 If its cycling or occilating between rich and lean on cruise, then its working good. Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2300951 Share on other sites More sharing options...
MANWHOR3 Posted July 1, 2006 Author Share Posted July 1, 2006 hmmmm.... i'll look into it again tomorrow, but i'm pretty sure that it was oscillating around 0.8 I guess that sensor is worn then. Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2301023 Share on other sites More sharing options...
Busky2k Posted July 1, 2006 Share Posted July 1, 2006 Yeah. An easy way to tell is to rev the engine to 5000rpm in neutral. The O2 sensor should go rich when you flatten the foot ie >0.7V, then down to 0.0V when you back off the accelerator. Then it should be back to normal on idle again. Sorry in my first reply I mean that it should occillate betwen rich and lean. The upper (rich) and lower values (lean) are ~0.0V-0.2V and the rich range should be ~0.7V-0.8V Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2301142 Share on other sites More sharing options...
MANWHOR3 Posted July 1, 2006 Author Share Posted July 1, 2006 oh, mine does this. I guess it's normal then. Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2301161 Share on other sites More sharing options...
paulr33 Posted July 2, 2006 Share Posted July 2, 2006 an AF Guage off the stock 02 sensor is pointless and wont ever give you anything meaningful. it will always bounce all over the place. dont bother with it Link to comment https://www.sau.com.au/forums/topic/124536-o2-sensor-output/#findComment-2301327 Share on other sites More sharing options...
