driving to work yesterday and went to put the drivers window up and it just didn't want to go. this has happened a bit lately and normally i just hit the door trim and it goes up. this time, though, it didn't. i've removed the trim and tried to help it up. put a bit of wd40 on the tracks but still no. when i push the button for it to go up, the regulator ticks but nothing happens. is it common for r33 s1 regulators to go or even the motor? got quoted $120 for the regulator and $295 for the motor assembly. was expecting about $50 for the regulator. anyone got one for sale? what do you think i should do?
https://www.sau.com.au/forums/topic/124561-drivers-window-wont-go-up/
Might be worth pulling it apart. Does the window go down still?
My passenger window would go up but not down, but the drivers side controls worked fine with it. I opened up the switch and the contacts just needed cleaning. I'm pretty sure they run a fair bit of current through them so they tend to arc and corrode over.
I had a similar problem with mine, hit the regulator and it went up. I pulled it apart, checked out the circuit baord and sure enough there were dry soldered joints. Have a look over the circuit board, you will see terminals coming through it that the solder has let go of. There will be a ring around the terminal where the solder isnt touching. Get a small soldering iron, put a drop of solder on it and all is good. Let me know how you get on.
Ken
ken, you are the man.
you just saved me between $120 and $160 for a 2nd hand one. that was the problem exactly. the hardest part was pulling it apart. took me about 5 mins all up to fix, and that included warming up the soldering iron. very easy to do. should've taken photos and turned it in to a tutorial. sounds like a common problem. thanks heaps for the help mate
Craig
Craig
No sweat, glad to help out.
on my s2 96 gts4 my drivers window is a bit wobbly but it goes up and down okay. however, on the passenger side it goes down ok but struggles on its way up it also makes a slightly louder noise? any suggestions what it could be
Same deal by the sounds.
Myself and a mate worked on his 32 with the same problem...open up the circuit board, find the related areas to the window respectively, and check for corrosion and rust. If so, cut it off, burn up some new solder and drip her on. Make sure there is oodles of power going to it aswell. if these things are ok, theyll shoot up and down in a jiffy.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
