  • Replies 41
We have this stuff at work called "never fog" it costs $2 and comes in a little packet, its a cloth that has some sort of anti fog stuff on it and you just rub it all over your window, works really well I hardly ever get fog appearing on my windows anymore.
Edited by Dave69001
n15mo... ur from brisbane.. i guess u dont know the weather down in melbourne... its terribly cold...
dave... where can you buy it??... sounds like an excellent idea...
We sell it where I work (carewash in mt druitt and norwest and envirowash in bankstown) im not sure of any places like Autobarn etc that sell it as its an American product developed for their harsh winters but ill try find out where is it is available for you :whistling:
I hate that No-Fog/Fog-X/Never Fog stuff, because it leaves an oily film on the windscreen that makes it look dirty and hazey in the sunlight... and if you wipe all of the oily stuff off, then you've just wiped off the product and it does sh1t-all!
I find just keeping the inside of the windscreen PERFECTLY clean and spotless is the best option. Then 10 seconds with a blast of hot air demists it quick as a flash! When your windscreen is dirty though, it takes AGES to demist the glass.
That stuff OWNS.
Seriously owns.
OR use the air con.
The cef didnt have air con I just used heat to get rid of it. Hot full blown for 10 seconds would get rid of the coldest fog.
Driving to work at 4:30am guarantee's my windows fogging up so a light wipe over of the AntiFog (made by RainX) and its 98% gone. The only problem with this stuff is if you put it on too thick than it actually works against you.
As gtst1976 said, just run the heater and the aircon at the same time. Set the temp to 20 odd, make sure the air flow is on windscreen, and bingo, demisted windows during the cold wet weather.
The air-con removes the moisture (humidity) from the car on a warm day, and it will also remove the moisture (fog) from the car on a cold day.
Edited by nickcorr
I found its a waste of time, as someone else said it leaves a greasy streaky residue, i might as well have sprayed crc on my windows. Got pissed with it to wiped it off the drivers side but its still on the passengers side. My flatmate said it best when she was in the passengers seat, "it looks like i'm driving drunk, but im not" lol..
The rainX window cleaner however works a treat :).
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
