hey fellas, i thought maybe some of u might be able to help me out here...
u can modify a car as much as you want but in all honesty, its your ability to drive that counts more than anything
my problem is that i cant seem to perfect my launch..so i was wodnering if anyone could give me some tips...usually i sit at about 2500 to 3000 and jus ease through the clutch, but i still get taken off the mark...eventually through 3-4 i can them most of the time but if i could jus master the start....
any advice?
https://www.sau.com.au/forums/topic/124595-the-perfect-launch/
i actually like a nice salad mayo sandwich, usually goes down and hits the spot nicely :whistling:
oh hang on, launch, hmmmm
anton sounds like you have the idea ... i would be more insisting on 2000 - 2500 rpm easing clutch out and gaining throttle as its coming out
a little wheel spin, or chirping of the tyres is fine ... just no major wheelspin.
its not as easy to launch as everyone thinks
unless u got an auto ... meh
Your avatar shows a R33, your sig shows "RB20DET" - so this might be of no use but...
My R33 (pretty much stock) launches best at about 4200rpms. Any lower, it bogs. Any higher, wheelspin to hell. But 4200 - I go off like a gunshot. It's very tricky (especially with a turbo), but once you find the sweet spot you're laughing!
Much easier if you get an aftermarket computer with launch control - you can preset the revs your engine holds at whilst you hold the throttle flat down, as soon as it detects any speed (cos you took your foot off the clutch) it goes bach to full...
I Have an R32GTSt. Mods are FMIC 3 inch turbo back eghaust, 12PSI Boost. I also have a semi button ceramic clutch. Launching was a hard task to perfect. Usually 3500 - 4000rpm for a "moderate" launch or a redline launch if out at the track and just ride it out.
For average day to day driving i usually take off at 1500rpm.
Hope this helps!
a little bit of wheelspin is better than bogging it down. i have a heavy single plate clutch and only have stock tyres (205's...i know they are crap, but my old ones weren't legal and i only paid $200 for 4 new tyres on stock r33 rims). putting 270 odd hp to the ground through them is rather tricky. i rev it up to about 3000-3500, load it up on the handbrake. then when you want to go you drop the handbrake, gas it as you let the cluth up quickly. use the accelerator to determine how much wheelspin you get.
Is the car in your avatar a GTR - or has it just been badged a GTR like some (i won't call anyone names) people do?
If so, up the anti and drop it from 3500 - 5500, that's the beauty about GTR's they stick, if not, 3000 - 4000 works for me.
Hmm Wheelspin... What if ur car is running on High Boost all the time??
how do u lessen as much wheelspin as possible
Sometimes i can smell clutch n it's burning or whatever
I rev it to about 1K or just a bit over.. Then Bang drop on the Gas
Still spins. Got 245'z Tyres, FMIC, 3 Inch Cat Back, Hks Filter n 9-10Psi of Boost. It doesn't get going till after 2nd... then goes all out once i reached 3rd..
It's a bit of a Problem when draggin other Fast Non-Turbo Cars.. aka V8's, SS, XR8 etc...
Edited by Black_CSR
  • 3 months later...
I rev till about 3000. Lift the bandbrake, let clutch out till the friction point and then release then hanbrake. I may not come onto boost as quick as the guys who drop and feather the clutch at 4000 but it's consistent.
Tyres and suspension play a monumental part aswell
Jeezus, this thread is filled with so much uncertainty that it's just not funny.
Few points for you to consider (for the drag strip of course):
A little wheel spin is better than bogging down.
Generally, this requires a little more revs, and easing the clutch out.
It is car dependant - therefore, you'll have to practice.
What I did before, was I would start at 3k rpm. I tried to pop it, it boged.
Popping it at 4 did a mini burnout, then bogged.
Therefore, for general semi quick launches, without absolutely killing the clutch, I just ease it out at about 4-4.5.
But hey, that's just how my car goes with my tyre, suspension, clutch, power delivery etc. Therefore, practice on your own car.
But the general principle is avoid bog, avoid burnout, a bit of wheels spin is ok e.g. 10% wheelspin.
hmm, when i had the stock 32 turbo, dropping it from about 2500 was the perfect launch. Now with the r34 turbo its impossible to take off. Wouldnt bother taking it to a strip, too hard to launch, id be looking at 15's.
I've tried riding it down from 4k, too much clutch burn, 3k, it bogs even if i let it slow or it wheel spins to the top and dropping it from everywhere means either bog or burn. I was driving my mates civic (91, twin carb, 1.6L), he was in my skyline, i was in front of him on take off for at least 50 meters, till spoolage and traction and lag fixed itself and the line overtook
gey assd rb20
Ok ill post a proper response about my experiences. In my old R33, it had turbo back exhaust, 10psi, Power FC, FMIC (191rwkw), rock hard tein susp, 5 puck brass button clutch, 255 wide K104 tyres, revs at 4200, drop clutch (foot flat all the way) & wheel spin half way through 1st, ran 13.5 @ 106 with 1.8 60’ (with granny shifted 3rd)
As adrian said, it's car dependant, so practice makes perfect.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
