Hey guys,
(I tried searching but couldnt find anything)
A few months back Autosalon mag threw in a free dvd. On it they had the Banzai CRX from high octane overboost.
Has anyone else seen this?
Short version - They do up a B16 powered CRX, bore it out to 1.8L and force 16psi through it then race it against various cars.
The question that has been bothering me is, why could the 600hp R34 gts-t Skyline only do a 14 second 1/4 mile?
surely skylines are faster then this?
https://www.sau.com.au/forums/topic/124665-banzai-crx/
that dvd is full of shit in relation to the crx, it makes unrealistic power on the dyno and is slow anyway, from memory it was only doing mid 13s so the drag races were also BS as if the competing cars were really as described the crx would have been destroyed.
and if the crx really made that power on the dyno then it would be doing at lot faster than mid 13s anyway.
that dvd gave me the shits as now i bet heaps of people think that their CRXs with a turbo bolted on can beat a 600hp gts-t.
Edited by siksII
https://www.sau.com.au/forums/topic/124665-banzai-crx/#findComment-2305887
I remember seeing that DVD. The stupid thing is that they got the CRX, spent something like $18000 on it (not including the paint job apparently), and it only ran 13s. Imagine if they had started with something decent like an R32, VL Turbo or even a V8 Commodore, it would be running 11s, maybe quicker.
I can't remember it beating a 600hp GTST, I remember it beating the XR8 and Aston Martin DB7, but the modified R34 GTR beat it.
https://www.sau.com.au/forums/topic/124665-banzai-crx/#findComment-2306890
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
