I've been told that the 180B Timing Chain Cover is the same as the L6 cover.
Is this so?
Does anyone know of any other motors that have the same part.
I'm reason I'm asking is because on my L24E the water pump area is corroded out really badly. I need to fix a large pinhole (second one since I've had her) and will have to build up the corroded areas with weld but I'm told that there is not enough good metal left to weld onto. The welding shop guy easily pushed a scriber through the casing in about 5 areas whilst we were assessing what to do.
All the wreckers near me have not got any L6 parts that are usable but one says that the 180B motor and maybe the 1.6 & 2ltr ones are the same. I'm waiting for him to show me one to compare.
Thanks
Wardie
https://www.sau.com.au/forums/topic/124679-l6-timing-chain-cover-compatability/
I think you'll find that any L series timing cover except L20B will do the job . To spell it out dont try L/Z or KA . All L's except L20B use same block height . I can't say for sure with LD28's but the rest of the L's should fit . Most common these days will be L16 , L18 , L24 and L28 . The only vsignificant difference will be the distributor mount adapter .
Cheers A .
PS am seeing Mr L series tonight , will confirm tomorrow .
Cheers A .
The LD28 is quite different due to not having a distributor...
The LD is also a 'mid' block (as per L20B), but not as tall as the Z24.
In short, the L14/16/18/20/24/26/28 run the same cover (and most other parts).
Thanks Guys,
I got one off a L18 and when comparing it to my original was amazed by how much meat was missing from mine.
I put it back together and she ran like a three legged dog, missing on one cylinder. Mucked around checking compression, leads, timing, valve clearances and anything else I could think. Eventually I narrowed it down to #2 pot after I did a run and pulled the plugs, #2 was wet and dirty. Swapped out the lead, swapped the dizzy cap, swapped injectors with another pot. Eventually put one of the old plug set back in and she fired on all straight away. I wasted 2 days because I never thought a new plug could be faulty. DOH!!!!
Wardie
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
