bought a dodgy blow off valve ( first ebay experience ) when i fit it the car was having all sorts of idling problems major power surges and just plain no power at all... took it off after the mechanics told me it was the bov not working properly...
since putting the stock bov back on i'm still getting idling problems when starting the car up (when cold) and it takes a minute to be able to free rev the engine because it sort of coffs and sputtlers.... also when driving the bov is much louder and it sounds like theres a a/m bov on there, it's releasing between gears and when coming off boost...
my mechanic checked it out and told me it's probably a computer problem and to see an auto electrician but that still doesn't explain the bov being so noisy, does it???
please help i know very little but don't wanna pay any more money to not get it fixed.....
https://www.sau.com.au/forums/topic/124685-blow-off-problems/
yeah it's connected properly weve tested it with that spray on leak findind stuff..
it's clamped an all but i personally think its leaking some were as well... but where???
cant follow the bov return pipe down far enough to see without pulling all the smic pipes out the mech's tested as far down as they could see but no good... could it be that the bov is releasing more down the return pipe now and as a result making more noise??
when driving it's only going bout 80% power but the turbo sounds like it's winding up much louder than before...
a big lesson has been learned bout buying cheap car parts....
was there a restrictor in the piping when you first took the stock bov off? i have heard of a few people that have found a restrictor plate plugging up part of the plumback pipe directly after the bov. if there was and that is no longer there then that is the extra noise problem.
oh well i'll soon find out off to the auto electrician.. will post results thanks guys
could you tell me what sort of bov you bought as i just bought one off ebay and when it arrived didnt look like a fair dinkum one it is a supposedly hybrid supersonic bov and not to sure to fit it now or not
auto electrician?
What a waste.
You had sparks plugs in there when you had the crap bov which caused overfueling and coughing and spluttering.
They are fouled.
Take them out, buy a new set of spark plugs (NGK BCPR6ES-8 (if they don’t have the -8’s you can also use the -11’s but will have to re-gap them)), put them in and it should be all good.
Cost you about $4 each plug.
well there was no computer problem, just a loose hose connection coming off the turbo...
i thought it was leaking and i was right and two different mechanics couldn't figure it out.. the auto electrician did...
thanks for the suggestions guys
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
