Couple of Questions:
Car is a R33 Nissan Skyline, with a RB25DET, and Garrett GT30 making
around 250 rwkw.
1. The Knock setting area on the Fc Edit Software under the settings 1
tab. There is a "Thresh" which is what it will flash on the dash with
if there is knock.
What does the "setting" reflect. On the RB25 default maps, its set at 9.
Also, My Knock sensors are reading 80 - 100 on some parts of full load,
and the tuner says he can't hear any knock.
He does quite a few XR6 Turbos, and says that he has to turn off his
knock sensors all together because since he's making so much more
power, the sensors are picking up general engine noise as knock. He
also said since the engine is making so much more power, it sounds
different and can fool the knock sensors into thinking its knocking.
(this XR6T is 11.5 @ 120mph Standard motor and turbo! Seen it with my
own eyes)
The main reason he turns off knock sensing is because then the factory
ECU tries to pull out 6 degrees. They actually edit the Factory ecu to
gain power.
Anyway... Could my sensors be over sensitive?
Since the water methanol Injection has been fitted, its making heaps
more power. I want to put the timing in, but I am too scared to because
the sensors are reporting high knock (when we can't hear it).
All input, big or small, is appreciated.
Thanks
Jono
around 250 rwkw.
if there is knock.
own eyes)
gain power.
Thanks
Jono
What he should be doing with the xr6T is de-sensitising the Knock sensor gain functions rather than turning it off completely. XR6T factory ecu can pull up to about 8 degrees if they feel necessary. It only takes 1 bad batch of fuel to cause damage. I definately wouldn't turn the knock sensor off in a customers car thats for sure.
I wish it where possible to tune the knock senistivity of nissans but its just not possible using PFC or factory management. I've found the nissan sensors fairly consistent in the topend at high load however there have been a few that I wish I could have desensitised. If he is happy enough that there is no detonation then be happy that its a safe tune. Get him to read the plugs after 1000k's to determine if there is need for a tidy up of the timing map. I've found that you have to be very progressive with your timing numbers throught the map as large variations in timing can give you a knock also.
the 9 referes to the flasing sequence it uses to run when the level is reached, 9 means flashe 3 times at 0.1 second intervals
i would be trusting the logic of the knock sensors and not ignoring them
they are too sensitive.
I've getting readings at 40+ and not hearing any detonation.
Can anyone agree with this?
Only had mine tuned for the first time in the last week by The Hitman.
The Power FC is set to flash at over 60 i think.
I get a small patch of flashing when at full load at about 3.5-4k revs. (hits about 80)
Hitman also said that he doubts you would be able to hear that and in the 'old' days, no one would have worried about it.
I might ring him later in the week and ask if i should do anything about it because it's always the same spot.
Mine has been knocking at over 100 for the last 2 years and I have NEVER been able to get it to stop reading knock.
Every time i hammer it i will get a reading from 30 - 100 no matter who tuned my car - if i do it myself or if i get someone else to do it nothing changes.
C&V Tuned my car last and he said to ignore the knock sensor readings because its not knocking on the dyno but it is reading high knock.
I would really like to get this fixed and get some kind of readings happening again so if it does actually knock I will know about it.
I noticed that my knock sensors started to read high knocks after i got over 300rwhp - when i had less then 300rwhp it was not sooo sensitive.
I too get some hi knocks, sometimes in the 90's but cannot hear it ping at all like the old days. If i put some optimax extreme this comes down to 60. I live with it, this is only on hi boost, low boost gives me around 30. Starting up gives me knock of 40.
Start up knock of 40 ? woah mine goes up to 10 on startup.
I did hear that if your knock sensors are screwed in too tight it can be very sensitive. I put mine on pretty much finger tight and it made no difference.
Anyone have any ideas how to get knock sensors working properly???
Based on my experience the PFC knock sensor numbers are a combination of loudness and frequency. If you have a loud knock, that doesn’t occur very frequently, you can get the same reading as a soft knock that occurs often.
For example, if you have one cylinder knocking loudly you can get the same display as if you have all 6 cylinders knocking softly. Obviously a soft knock at 6,000 rpm may give a similar reading to a louder knock at 3,000 rpm.
So saying stuff like I get “100 knock sometimes” is not at all useful for your tuner. You need to be able to tell him at what rpm, what throttle position and what sort of load. If you have a Datalogit this is obviously very easy to do from the log. If you don’t have a Datalogit, then the best method I have found is to set the Commander for 4 displays. Being knock, rpm, TPS and AFM voltage. When the dash warning flashes, I can see the knock reading and remember what the other outputs are at that time. This is obviously easier with a passenger or a video camera (the poor mans data logger) pointed at the Commander display.
It is so much better to say to your tuner, I get 80 knock at 5,500 rpm with 100% throttle and an AFM load showing 4.5 volts. That tells him where on the fuel and ignition maps to start looking.
:nyaanyaa: cheers :laugh:
PS; if you get reduced knock when you use 100 ron (compared to 98 ron) then chances are that is REAL knock and should be attended to.
I have had this problem for over 2 years now
I have had it tuned and tweaked so many times, and its still the same
I believe, along with my tuner, that my knock sensors are indeed playing up. Ever since pulgging in the FC-Logit stuff, the knock sensors have played havoc. Doesn't matter what we do, 10* or 18* timing at full noise, it knocks to about 80 at WOT at around 5400rpm
No noise, no puff out the exhaust, just on the hand controller. The rest of the run is at around 25-40
To the point now where I don't even drive with the hand controller plugged in!
I reckon its something to do with FC-logit, but what I have no idea
Only once I have had a similar problem, that was at 5,250 rpm in an RB30. What I did was set the ignition timing from 4,500 rpm to 6,000 rpm at zero and richened up the A/F ratios to 10.5 to 1. That totally eliminated any chance of real knock. Then I went for a little walk around the engine bay on the dyno with the chassis ear. It turned out to be the remote oil filter sandwich plate tapping on the oil pressure gauge adaptor. They were located right under the rear knock sensor. There was obviously was a slight engine vibration at that RPM, which I later traced to an unbalanced pressure plate.
Every other time I thought I had phantom knock, it went away with the extreme rich and retarded settings. So it was real knock, and needed to be tuned out.
The answer is there, you just have to be prepared to spend the time looking for it.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
