  • Replies 89
email subjects altered to contain more info, and email contents summarised a lil. I'll let the forum start sending out some emails before I tinker with it more... also might look into the stupid double spacing in the mails.
hmm looks like it didn't work too successfully. back to the drawing board... they seem to change the stupidest little things with each revision of invision.
Try this:
Up the top of the page click on "My Controls", then under "Subscriptions" click on "View Forums", then use the tickbox on the right and then select "Unsubscribe" from the pull down box at the bottom and then click on the "with selected" button.
It's funny because now that the email subject are all the same, the web interface to google mail groups them all in one convo, which really sucks.
Used to be good when the subjects had the thread title in them as then gmail would keep them all together.
Any idea when/if this might be fixed?
as soon as i figure out the new IPB structure. the way the forum is set up with caching there's 4 different scripts that have the same information, and I don't know which one is being accessed... i'll have to sit down properly and nut it out.
Sorry for the delays people.
Cos I spend my lunh hour (and a half) on the internet...
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
