Ok would like to know if anyone in the forum has any knowledge on 2 piece brake rotor from any maker that fits a R32 GTR. I only need the rotors as i will use the standard calipers which i will have a bracket milled to fit.
Update i have found a company who make the 2 piece rotors for the R32,33,34 GTR skylines.
Why dont you have a look at their web site and let me know what you think. There is even a forum section on this subject with very quick replies to the questions i have asked so far.
regards
http://forums.racingbrake.com/viewforum.php?f=7
Edited by tacker
https://www.sau.com.au/forums/topic/124765-front-355mm-disc-brake/
There are plenty of places that will do this for you.
In Melb call RacePace in Bayswater, Ben works on all sorts of Skylines and races R33 GTR.
If you go 355 mm disc you will be very locky to get it to fit in a 17' rim, only 1 or 2 types of rims will clear these, better to go to 18".
tacker, how much will the rotor cost?
I've got a set of second hand F50 Brembo calipers with ?pagid pads and 355 mm rotors. Basically everything you need to bolt it into a nissan minus the mounting bracket. If you want them let me know.
the std GTR32 caliper will have too much curvature at the outer edge to fit a 355mm rotor...
plus it is very unlikely that even the slimmest caliper with a 355 will fit under a general 17"... something like a Volk TE37 has more space though
Not sure either thats why i am looking at every option.
I have 18" wheels so that wont be a problem i hope
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
