Ok got my self some Motul Turbolight 4100 & now i need filters so i can whack it all in
I did the search & all i seemed to find were the Ryco/Valvoline Alternative part #'s
Could someone please tell me the Genuine Nissan Part numbers i should ask my local Nissan dealer for to get the right Oil & Fuel Filters for my car (S2 R33 - RB25DET) & also is it true that they are the same parts that go on a SR20DE?
Thanks guys/gals
https://www.sau.com.au/forums/topic/124835-genuine-nissan-oil-fuel-filters/
just use ryco/cougar/valvoline-you know what i mean. makes little difference, as long as you change the oil as regularly as you should. All oil filters will be called 145a? just did a change on my car used a ryco and motul 4100 car is noticeably smoother im very impressed.
As for fuel filter im not sure, but will soon be changing mine too
Hi,
Nissan Part numbers as follows:
OIL FILTER - 15208-H8911 - $7.95
FUEL FILTER - 16400-41B05 - $31.55
They will fit some SR20DE's, it depends on model of car.
Cheers
Jo
Edited by Jade
Hi,
Cheers
Jo
Legend!!! Ok well as long as they fit my R33 S2 its all good ;-)
Thanks Jo
Sorry for hijacking ur thread >_<
Jade: What is the nissan part number for an R34GTT oil filter? I know they use the smaller one Z442 (nissan Micra) as opposed to the R33 ones Z145a. I've heard the Nissan ones are cheaper than the Ryco or aftermarket ones...
Thanks.
Hi,
Cheers
Jo
how often do the fuel filter need to be changed? Is it every oil change?
Thanks.
Hi,
The R34 GT-T is the same oil filter as previously stated however, there is a smaller OEM oil filter that we fit to some Skylines. Part number is 15208-53J00 retail is $15.25
Cheers
Jo
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
