I generally find that if you are polite to cops and are honest and humble (not to the point of digging your own grave tho!) you get off lightly. If you give them any lip or claim you were doing 40 when you were doing 120 then you're gone.
Cops aren't idiots, and they have a really tough job to do (back when they used analog UHF I used to listen to them on occasion and it's a shit job sometimes). You will get an absolute c*#@ occasionally but most of them will give you a fair go if you don't antagonise them.
Yeah no more listening, with the switch to digital, and soon to be encrypted...
but yeah, its best to be honest and cop it on the chin.
I got done doing 130 in a 80 zone in my diesel gemini about 8yrs ago when i started driving , til this day I still think that bloke was the coolest cop , he did book me but I was doing the wrong thing he only done me for 15 over the limit not 50. He asked me
COP " none of my business , but why were u speeding"
ME "I been driving all day and have not been within 10kays of the speed limit it the first bit of open road i had i was just driving i gunna have to take more notice of my speed"
COP "mate I know what u mean i wish people would do the speed limit , how do u think i feel when i travel behind a car they do 30kays below the limit F@#k it S#$ts me , look at this d#$khead he would only be doing 40 i wish i could book him"
ME "OK"
COP " how the hell did you get 130 out of a diesel gemini , look mate slow down a bit , I know your on your P`s but dont do 80 in 100 zones you will just hold people up just make sure u dont go above 100 and we will not book u , now go home and drink those beers in the back seat and have one for me"
ME "yes sir"
Yeah well I was all "cops are great" until some PMS'ing troll decided she'd book me for a red light offence the other night.
Write a letter to the RTA, and try and appeal it. It won't cost you that much and it might work.
I've found the RTA to be relatively receptive to this kind of thing.
I got pulled over a couple of weeks ago for doing 66 in a 50 zone was lucky enough to get a freindly cop who let me off with a warning.
After telling me to slow down as it was a 50 zone, he then got in his xr8 and absolutely floored it away from me which seemed somewhat hypocritical.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
