  • Replies 238
After just doing a bells run with the audi guys, my theory is that it would be eaiser to meet at richmond, just before bells line of road, going from parra to richmond id imagine that heaps of people would get lost, stuck at lights etc, straight to richmond is pretty easy and if you get there at 10 you will still get to bathurst after 1ish.....
just a thought!
it would be great but remember that its still a public road and i dont know bout u guys i would be so tempted down conrod and there is always cops there.
it's not one of THOSE cruises burnsie >_<
generally people on these cruises are very well behaved and enjoy going for a sunday drive so to speak.
just a thought!
agreed 110%
dam you soft people, 3 hour drive is NOTHING!!!!!
why not just split into two group, the softies go cruise down george st or wherever, while the hardcores go to bathurst..........SIMPLE!!!!!!
sure, George St sounds good!
looks like Bathurst is the pick of the lot
