Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
  • Replies 125
Posted Images
Would it be possible to incorporate braided houses into this.
Say I puchase the core, relocator and thermostat and then supply my own hoses at a later date?
What I am getting at is: are the relocator, fittings on the cooler and thermostat able to take the screw in ends on braided hoses?
very interested.. will hopefully have some money freed up in a couple of months
No worries
Yep, not a problem, they will fit
Does any one have these fitted to their car?
I will def be in as soon as i have cash, thank god for the long time frame gb lol.
Will i need a high volume oil pump because of the relo kit the oil filter will not be next to the block? So will the oil reach the filters no worries if i have the relo kit on the firewall or strut tower for example?
If i was to go for the smaller oil cooler core (polished core) that you posted a pic of will it still cool fine for street applications as i also believe that the other core will be too big for my use and to try and find space in the engine bay for it lol.
Cheers Simon
so if i bought a dual filter relocator, a thermostat, and a oil cooler core, everything that is needed for installation would come with it? or would i need to get hoses made up?
Everything comes that you need to install
Cheers Simon
Hi Simon,
You wont need a hi flow oil pump(such as N1 etc). As the thermostat stays closed, while its cold and only opens when its hot. so meaning the oil is much thinner when its warm, rather then cold. the stock oil pump fill flow fine - even with it mounted many feet away from the filter base/block it self
just another really simple question (that is probably so simple it's stupid, but it's something that's been bugging me for a while)
when you do an oil change - how do you get the old oil out of the cooler core/lines?
You undo the filter, undo the sump plug, let it drain for ages, then if you want to, undo the fittings on the core and allow whats in there to drain back to the block, and then that will end up going out the sump, if you are really keen on getting every last bit out, undo the core and tip it up - but it doesnt hold enough oil to really justify that IMO
Thanks for that..
sorry to be a pain with all the questions, but does the sandwich plate for the relocator have any bungs in it for sensors (i.e. oil temp and oil pressure sensors)?
i'm just trying to cover all the little things that people seem to want to know about, judging by previous threads :D
Thanks for that..
Theres nothing wrong with asking questions :D
Can get a plate with gauge inputs if required but they made in Cchina and i dont want them to be included in to the kit as they are prone to cranking and leaking
For the people who have paid - your kits are in the mail as of yesterday, and i know one arrived today at its destination thanks to express post
defintately interested in this. count me in on one within 2 months.
definately.
hip hip hozar for the long gb period!
cheers. james.
definately.
cheers. james.
Hahaha no worries mate
Yeah made it long so everyone could have a chance :banana:
Subscribe- I have to check my oil cooler kit first (got it last friday but havent opened it up)
More so interested in the thermostat. What size Barbed fittings does it have?
Can it be supplied with a 70-75 deg spring? Or can it be adjusted to open a little earlier?
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
