IM all so looking for someone wreaking a RB20DET Engine as i need the following bits and pieces:
*Power steering bracket
* Rocker covers rubber hoses (where does the last hose from rocker cover go to heads near turbo)
*Cross over pipe bracket (above turbo )with bolts
*The hoses from AAC valve to Air Regulator to cross over pipe with t piece as well.
*rubber elbow from turbo intake
Thanks DAMO!!!
Also looking for the Deternation sensor loom that plugs into main R32 engine wiring loom.
And a RB20DET HKS Style Super Sequential Blow Off Valve adapter.
Thanks Damo!!!
86vl5spd, I've the manifold and all the parts above the turbo, may be that's what you need, I'm not really sure. By the way, I'm from Adelaide too, may be I can show you what I've got. My number is 0402 452 455 if you're still interest, thanks.
'cookiebear' Thanks for the offer mate but ive pretty much got all the Parts i need now all i need is
Deternation Sensor wiring loom that joins into main engine loom?
And would any1 have a HKS SEQUENTIAL BLOW OFF VALVE adapter?
Thanks Damo!!!
