R33 gtr would be my guess too.
check the plug when you get it, compared to r33 gtr pinouts and go from there.
i doubt they would use a different ecu/harness just for the stagea given it was an aftermarket modification to stageas by autech.
good idea to look at the pinouts when the car comes. I saw a greddy one for under A$600 in Japan looks good too but tis for a r32 and r33gtrs though
thanks guys. Then next question which brand and model? And average one that will do the job
A "Power FC" is an after market computer that is made by Apexi... there is only one brand of Power FC, if you are talking about other brands of AM computers then I think most people will point you back the the PFC anyway. I hope that helps... try this link seems like the go!
So "Power FC" is the model made by Apexi? Am i right? If thats the case how about othe FC brand? Which ones? Cos i cant read freaking Japanse from the freaking Hyper Rev mag. Cant read the specs
theres 2 versions of the power fc and one is the air flow meter version and one gets rid of the air flow meters and uses 2 map sensors called the power fc djetro
the AFM'd version is fine for most power unless u are going totally insane and want over 500hp or so at the wheels, and even then the afm'd one is still fine.
djetro is $1600 all up with map sensors etc and normal power fc is about $980 or so
If thats the case i will opt for the one w/o the air flow meter then. Which brand though? Hks?
its an apexi power fc djetro (non afm'd version) and its like the m800 ecu is a motec and the smc4 is an autronic, and mtx12 is a microtech
power fc is one specific ecu (well 2 versions as i said earlier) by apexi and nuthin to do with the name of aftermarket ecu's in any other brand.
hks make an f con pro ecu but they are not good because no one tunes them except one shop in Oz i think from memory
afm'd power fc is much much easier to tune and comes with a base map to start tuning from where as the djetro is a start from scratch ecu and requires a good 3-4 hours tuning just to get the engine even running.
sydneykid reccomends the afm'd version in every application due to cheaper price and easier/cheaper tuning.
ive actually got a gtr power fc djetro sitting in the box brand new in my room waiting to go on my stagea in the future once i put the other engine setup in :thumbsup:
plenty of over 500hp cars and one 890hp gtr is running a djetro in WA so they are pretty good ecu's :/
just remember over 500hp reliably in a stagea is gonna cost over 20k just in mods easy! thats engine rebuild time if u want it to last as plenty are blowing pistons and the like with that sort of power.
around 450hp is the cheapest and stock engine should last a fair while on that power level.
so what im saying is its best to use the afm'd version in 99.9% of cases, and even the vmax apexi drag gtr that runs 8 seconds still runs afm's.
ive actually got a gtr power fc djetro sitting in the box brand new in my room waiting to go on my stagea in the future once i put the other engine setup in :D
plenty of over 500hp cars and one 890hp gtr is running a djetro in WA so they are pretty good ecu's :D
Thanks cruiseliner for clariying the terms. I think i will be getting the power Fc commander.
Thanks again
