Few things been sitting in the garage for far too long...
All off 95 R33 GTS-T except for the pod setup which is as stated. Don't like the price...make me an offer.
Prices for pickup from Perth metro. Delivery at buyers expense.
CAI Box: $160
Purchased off Maxx from these forums some time ago. Never fitted, does not work with my VERY direct intercooler piping. If you use the stock piping location through the engine bay it should work perfectly. Great build quality. More info available in the original post...
http://www.skylinesaustralia.com/forums/in...=radaitor+panel
Series 2 Rear Spoiler in White: $50 SOLD
Sticker as pictured 'Nissan Motorsport International'. Brake light works perfectly.
Floor Mats: $50 SOLD
Full set of 5. Drivers side dirty and worn through where clutch foot rests.
Sub & Amp Box: $150
Missing one sub and amp. All hand made with stainless steel front cover and carpet around the rest.
VERY well built, fully sealed 3 cubic feet box. Amp and Sub can be put back in if the incentive is
good enough! You can see from the original image what it looks like with an MTX amp and both subs.
Can get dimensions if interested.
Lancer POD and extras: $80 SOLD
K&N Pod with custom made AFM adapter and custom 2.5 to 3" stainless piping with stock hose connector.
Includes CAI pipe. Direct fit for 1.8ltr models. I think the engine is the 4G93. Your little brother will love it :thumbsup:
Contact via PM or mobile 043 800 1990
Further Pics on request.
post-8519-1152002184.jpgpost-8519-1152002202.jpgpost-8519-1152002212.jpgpost-8519-1152002222.jpgpost-8519-1152002230.jpgpost-8519-1152002247.jpg
https://www.sau.com.au/forums/topic/124865-r33-gts-t-parts-for-sale/
  • 3 weeks later...
Ill take the sub box if its for 15's ^_^
sorry mate. forgot to mention that. the box was originally made for 12's. wouldn't imagine 15's would fit even if cut out a bit, but can check if you like?
top offer on the CAI box so far is $130... will do it for $150.
will do the sub box for $80 without the sub in it...which means that the sub is also up for sale. top quality MTX 6000 series. $70.
  • 3 weeks later...
pod off the lancer now also gone. still got the CAI, sub and sub box.
also have Nismo LM GT2's in 17" with tyres becoming available in the next week. price around $1300. pm if interested or wait for seperate post with them next week.
  • 2 years later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
