Ultimate 98
Rosie_1008
 Share
  • Replies 58
either way, studies conducted recently said that they expect petrol to run out in 7 years unless new areas are explored. That and the current conflict with places like Iraq puts our petrol demands at an all time high.
Better enjoy your "ultimate" for the next 7 years :yes:
Nuhh thats bullshit, theyve been saying that for 20 years, its just used as an excuse so that the fuel companys can keep rising the price...
and really, whoopty f**king doo, in 7 years, oh well jsut spend $1000 odd $ and convert the fuel lines to be able to handle methonol/ethonaol problem solved >_<
Quote form a BP Ultimate brochure:
"BP Ultimate offers advanced engine cleaning performance. it actually cleans your engine as you drive, reducing friction and making it run more efficiently for longer ....... BP Ultimate can prevent as much as 97% of the inlet valve deposits that can form when using regular unleaded .......... test results from dyno testing 2 FPV GT's after the 2 vehicles had run for 7,000k's under identical conditions, the power output of the car running BP Ultimate was 13.8Kw greater..... our testing has shown increases of up to 43kms per tankful on average fuel consumption of 9.5L per 100K's" ... and the story goes on.
Rod
Rod
Thats all well and good but i wont to know HOW they got the 13.8kw increase.
Were they able to advance the ignition due ot knock levels being lower than before, were the FPV's the turbo model and they increased boost (if so then other mods required) its all well and goood saying that they had a 13.8kw increase but i for one would like to know how they found the additional power and also some dyno charts overlapping there runs.
As for the 43kms increase per tank full, again this can all come down to the tune.
When i first had my car going i was lucky to see 2ks to 10L and it was an expensive car to fill (hence why i didn't drive it much) but after a tune i saw a remarkable difference with fuel economy (i actually had economy :( )
Before the old girl went pop i was about to get 100K's from about 8L driving normally to and from work.
I was able to get 100K's from about 13-15L with gate (:wave: mmmmmmmmmm gate)
Obviously its going to make a HUGE difference with the extra RON and this will inturn let people tune there cars for more ignition and boost and if need be more fuel.
Bring it on i say and its long overdue but i would still like to see there data from tehre testing.
BP Ultimate isn't something new (it obvioulsy is to Tassie :eerm:) but its been around for a while on the mainland and i cant see that they would of changed anything to bring it to the Apple Isle.
Cheers GMB
im not sure if id worry about using it on a stock motor like mine. especialy when i only realy drive it to work. and the extra kms you get per tank would have to be added up against cost.
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
