mmmm yello peoples
I have the genuine a31 front lip in minter condish its red too sittin in my shed got me a wonder bra woot woot and the ceffy floormats though im not sure bout getting rid of them there hard to come by so if ya keen on it $500000000000000000 nah i dunno frieght from Goolwa SA 5214 and whatever its worth i dont need it anymore its just sittin there bein lonely sms me 0419847512 dun bother ringing i never manage to answer :ermm:
  • Replies 43
guys, wouldn't it be wiser to mould one up?
i have the genuine lip, as stated per post, to be honest i'm not really willing to seperate with the lip anymore, but i would be more than happy to get moulds made if you guy are willing to pay up,
you're not talking about this lip on the bottom of my old man's front bar are ya?
i can pull it off if you guys want to mould it... i'm sure dad wouldn't miss it for a few days.
My car had one :blink: However it was kinda hanging off so I ripped the remainder out hahaha
likewise! it was in 4 pieces hanging on by the bolts thats it haha
i have the same front lip aswell... ill have to get pics as im leaving it on with my cut out front bar... looks so sexual... uras sides and rear shouldnt look too bad... and it will really show off the 18x9.5 +12 front vs'kfs
WHOA - undershrowd... i dont reackon i've ever seen one of these on a ceffy yet! nice work!!! :D
haha yep its as stock and boring and factory as it comes. Even the wheels are factory option BBS pieces. Its for my dad to drive around in so it suits him just fine.
Oh it aslo came with factory option doileys, but I haven't had the guts to put em on :D
  • 4 months later...
  • 5 weeks later...
newbie here from the uk and just want to say that this and the substitute parts page have been a total life saver for me here, think there are only about 10 cefs at the most that i know of in the whole of the uk so u can imagine wat its liek to get parts anyway i just tried to put a 180sx front lip ( called a prefaceleft 200sx s13 here ) on the cef bumper today and :rofl::P . I dont know if its me, the cef or the uk version 180 lip that was wrong but im be hard pushed to say its a direct fit or even a close fit
normal way around the lip is a good 4" to wide and if u turn it around so its upside down its still at least 2" to wide and completely different shape, so when i bent the edges of the lip round the cef bumper it flared out like a uras kit and dipped in in the middle
i'll get some pics as its taken me a good 3-4 hours of cutting chopping and sanding to get it to a near half decent fit
i was thing of doing this to mine s13 front
eww s13 frontend looks like arse on a cef... it dips too much in the fornt, which is OK for a coupe, but on a chunky sedan looks wierd.
OMG disgusting... makes it look even weaker than it is... like a fat guy sqeezed into a small tshirt
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
