Well my car just dynoed 212kw @ 18psi.
My mods include:
Microtech LT-8
Custom Frontmount
3.5 inch dump to cat 3 inch for the rest
Hyflow T3/4
h/d Clutch
Vl pusher pump as well as standard intank
Standard air box
Well i don't know what everyone else thinks but this seams a little low for the modifications. I though atleast 257kw because have beaten a certain silva with a rb20 before.
The dyno was not in shootout mode and had a ramp rate of 100
https://www.sau.com.au/forums/topic/12491-just-dynoed-my-car/
Did you dyno it with the bonnet down?
Thats the best way to get a more realistic figure. It is always a lower figure too.
I wouldn't worry about the figure if it was an improvement.
The real measurement is beating that 'certain silvia' and doing some quick times around your favorite circuit or drag strip.
Stop getting all hyped about the dyno figure.
It's a peice of paper, just like toilet paper its only fit to wipe your ass on if its not being used to help tune a car.
So what if the silvias got a better dyno readout. Scan yours into the computer and change it with photoshop to read 1000rwkw, then you can beat him at the races AND in a dyno paper stand off!
Yes you can say i'm a little focused on the dyno readout, I guess 212kw is not enough. The tune on the car was pretty S&*t, as soon as i gave it a boot full it detonated the loudest i have ever heard it. Sooo in 2 weeks it will be going back on the dyno, the same one as the rb silvia.
I'll let everyone know how it goes!
:D
Hi sik32, is this an RB20DET? No adjustable cam pulleys? No injector upgrade? No adjustable fuel pressure regulator? No internal mods? Standard camshafts? No pod?
If it's a roller dyno (not hub) 212 rwkw is 360 bhp, that's pretty good for an RB20DET with the mods you have listed. I'm surprised it didn't run out of injector capacity.
I sort of agree with the other guys, except I reckon the dyno might be a bit optimistic.
PS; let us know the dyno shop that the Silvia runs on, I want to take my car there and get a good bit of paper to wipe my butt on as well.
My mods include:
Microtech LT-8
hey sik32,
I'm too am running a LT-8 on my recently purchased GTS-4.
Just wondering how you find the driveability of it in your RB20?
How's the economy if your just cruising along in 5th gear?
I don't think they have closed-loop cruise mode. So they don't use the oxy sensor, do they?
What about initial start-up?
I know the LT-8 doesn't use the idle stepper valve. (the thing on the end of the plenum) So do you have some sort of air by-pass valve to compensate for the greater amount of fuel at start-up?
I'm just asking cos I find that mine never starts cleanly especially after I haven't driven it for a day or so. Sometimes it even seems like it wants to stall itself cos of the lack of air (revs drop below 500)
As far as the economy on my car, it pretty bad considering that I hardly ever boost it around town. and I spend alot of time cruising in 5th gear. something like 350km to a tank:(
I haven't had a chance to dyno it yet but hopefully will in a few weeks.
anything you can enlighten me on?:P
ok Interloper, First of all I find Microtech a great computer if you are on a budget. Drivability is fine, as it drives like the standard computer, but there is a few things that dislike about my Microtech. Cold starts, the car sometimes stalls on the first turn of the key and will not idle properly until the car has warmed up properly. This seems to be a problem that most cars with microtech have.
Fuel ecomomy, well that went out the window along with my standard computer. Microtech is Very bad on fuel, this also may be caused by the tuning as I like it too be a little fat. Even when i'm off boost and on the highway it still sucks fuel like no tomorrow.
Yes approx 350km. If i could do it all over again i would chose apexi or motec because of money i have wasted on fuel i could have afforded either of these. No Joke
Good luck with it all:D
Ps thanks for the toilet jokes guys!!!!!!!:bahaha:
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
