hey guys,
i had the a/c compressor in my GTS die a long time ago now, and i'm trying to source a replacement. I got a quote from JustJap for $495 and i'm wondering if i should really be paying that much - i know they're expensive, but is that my only option?
someone else mentioned they should be roughly $200 from a wreckers - is there anywhere around melbourne that i may be able to get one?
thanks,
simon
https://www.sau.com.au/forums/topic/12492-ac-compressor-on-r33/
Rick over at Traction Tyres was bringing in a 1/2 cut RB25DET from NZ for his race car. Might want to ask him nicely if he's willing to sell the A/C compressor to you (obviously doesn't need it for the race car).
  • 4 weeks later...
hey mate i have a a/c compressor its in working condition mine stuffed up also and i came across it, and the machanic that was putting it in said that he doesnt like to use other ppl parts as then he wont cover it for warranty therfor i have spare air con compressor never used and still have the receipt but im sydney and my asking price is $150 if your willing to pay for postage and your current pipes will fit straight on it. let me know or pm me?
Guest bucket1
My compressor stuffed up about 2 weeks ago and so far I've got quotes of around $300 - $400 for a used one from a couple of NSW wreckers (none down here). The guys from justjap claim they've been selling a few recently, obvioulsy they starting to get to the end of they're usable life. If anyone knows of where I can source a reco or new one, I'd rather fit that than get a used one that may have the same problem my last one had. It has been suggested that I replace the mechanical compressor with a 12 volt eletric one, anyone had experience with this sort of modification? The place I got to look at it reckons that they can't get an aftermarket replacement and doesn't know if Nissan Australia could get one for me without the part number.
Guys,
A Deisel Kiki, or Nippon compressor has RRP of $1000+. Nippon Air in Melb can rebuild them for an authorised fitter and that will mean wnty.
I have seen my fair share of A/C comps... fitted hundreds actually and my tip is... the wreckers are always a punt. You outlay $400 and then six months later booooom... another $400!!!
That adds up to a re-manufactured one with oil to compliment latest type gasses
Ciao
  • 3 weeks later...
Guest bucket1
Thanks Targa Tom, the one I had removed was by ZEXEL and I have been told that it is harder to get than the Nippon, besides that the fitter who removed the stuffed one has turfed it so I can't get it rebuilt. I am currently making enquiries with Mobile Air Con in Sydney who may be able to get a replacement, fingers are crossed.
Read! JMS and Justjap have them almost all the time... they are NOT hard to find and they are NOT expensive...
Using newer types of gas?!?!?! 134A is the current type isn't it? Was last i looked... thats what they use anyway!
plus, make sure you get new seals and shit when it is re-done.
easy
mines buggered - the nissan a/c compressors arent exactly the best quality. Ive taken mine out and basically did the ring around but noone in perth had a gen one - so i got a brand new one for $300 and just need to make up the bracket so it fits to an R33 :P
Uniola UP120 - i think.
My dads making the brackets up - or will be - if he has any problems i'll let u know. Im not really impressed about him going anywhere near my car it always spells trouble so ive been putting it off as long as possible - but the air con guy is starting to get impatient cos he pulled the old one out and needs to refit the new one ot get paid. I'll keep u informed :P
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
    • The switch part, is the switch you use to turn the lights on and off in the car.   The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short. Now it's a case as GTS said, of physically finding the fault. The fault could be:  metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through. Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered. Also check for anywhere there could be high heat, especially if heat shields are missing. Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night. You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
    • Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
